Clunking Noise from front wheels!
Old Jun 10, 2003
cheevdawg's Avatar
cheevdawg is an unknown quantity at this point
Hey everyone, newbie here.
Alright, well i had my progress springs put on about 2 weeks ago and everything was fine with them, i just needed an alignment, so i went to the closest tire place to get one, but they found out that my outer tie rods were threaded, so i had to have them get me new ones and intall them. Then, when i got my car back, the front springs clunk now while im turning. The guys at the shop said that the spring just needs a few weeks to settle in and it should be fine. Can anyone else vouch for there opinion? or should they be able to fix the noise?
Thanks
Old Jun 10, 2003
TOOLOWCIVIC's Avatar
Give it some more time to settle in.
Old Jun 10, 2003
cheevdawg's Avatar
Thanks TooLow, is this a normal problem?
Old Jun 10, 2003
VNlilMAN's Avatar
The Standard One
just when turning? what about on bumpy roads
Old Jun 10, 2003
HYPR DRV's Avatar
Since 1977
HYPR DRV will become famous soon enough
Go ahead VNlilMan, tell 'em about the $3.00 coil wrap solution. I'm tired of explaining it to peeps.
Old Jun 10, 2003
cheevdawg's Avatar
On bumpy roads i hear a little noise, kinda sounds like change bouncing around in my wheel well. but its not loud enough for me to worry about. (and no, its not the change in my change holder that i hear..haha) But other than that, its only when im slowing down and turning at the same time.
Old Jun 10, 2003
VNlilMAN's Avatar
The Standard One
haha fine fine i'll explain it..
try getting cable wrap from radio shack. just wrap it around the coils on your springs... the reason why you probably have the noise is cause the coils or the springs are hitting the perch(the thing it sits on). the cable wrap just prevents the metal hitting metal your [probably] hearing...
after your done remember to send me some of the cable wrap so that i could do mine
Old Jun 10, 2003
HYPR DRV's Avatar
Since 1977
Alright, here's the deal: I went through all this crap already so I'll save you the strife. The clanking your hearing over small bumps is the metal spring rattling against the metal cup that it sits in. Stock springs come with a coil sleeve that insulates this noise. If you still have ur stocks, check 'em and see. But it's not doing any damage, so don't sweat it. The noise your hearing when you turn the wheels is the dead coils rubbing against each other. To fix this, go to Radio Shack and buy a spiral cable wrap for 3 bucks. Then, jack up your car until you get decent space between the dead coils on your front springs. The dead coils are the coils that aren't being used (hence, "dead") located at the bottom of the spring, sitting in the cup. Once, your car is jacked. Cut about 3" of spiral cable wrap and slide it around the dead coils to act as a spring isolator. This will prevent the springs from rubbing thus ridding the noise. Do this on both sides and you're all set. To get rid of the clank going over bumps, you'd probably need to take the springs out and slide the stock coil wrap over the very bottom coil, but that's just too much trouble for me, so I haven't bothered with it. Not doing any damage anyway. Yeah, so try that.
Old Jun 10, 2003
HYPR DRV's Avatar
Since 1977
Oh, sorry you beat me to it. LOL, you still haven't gotten coil wrap. Man, lazy!!!
Old Jun 10, 2003
cheevdawg's Avatar
Thanks guys VNlilMan & HYPR DRV. Ill try that solution. And im sorry, but your gonna have to buy yourself your own cable wrap, im sure you can make the $3 somehow. but thanks for the advice!
Old Jun 10, 2003
HYPR DRV's Avatar
Since 1977
Aw VNlilman...He totally dogged you bro. Advice isn't even worth $3 these days. Sad, sad world. Guess you'll just have to keep the noise. OR GET YO A$$ UP OFF THE COUCH AND GET TO THE R' SHACK!!
Old Jun 10, 2003
VNlilMAN's Avatar
The Standard One
ya i beat you but you explained it so much better
hypr to get to the bottom coil, maybe try doing this... put the wrap as low as you can and try to slide/squeeze it to the bottom? cause ya a spring is a spiral so maybe you can get to the bottom like that?
i know.. psh i should stop giving advice... its not even $3, your going to throw the rest away anyways. why not hook up someone that helped you.
haha its koo tho, i dont really expect anyone to send me some.
ya i think i'll just live with it.. i did for the past year so
Old Jun 10, 2003
HYPR DRV's Avatar
Since 1977
Yeah, actually tried that but couldn't get all the way to the bottom cuz' it's sitting pretty tight in the perch, so I got it as close as I could and it's tolerable. Anyway, send me a PM with your info. and I'll send you some coil wrap. Sorry I couldn't last time cuz' I was going outta town, but no problem now if you REALLY want it.
Old Jun 10, 2003
cheevdawg's Avatar
Good idea, how bout you stick to giving advice, and then maybe when you need some advice, maybe ill be able to help you. that should make up for the left over cable huh?
Old Jun 11, 2003
SedanBoy's Avatar
SedanBoy is an unknown quantity at this point
can anyone point me in the right direction as to where i can find a pic of this cable wrap so i know what to look for?.... thanks guys...... btw, are there different sizes of wrap or is there only one?....thanks
Old Jun 11, 2003
HYPR DRV's Avatar
Since 1977
SedanBoy: Just go to Radio Shack and ask for a "spiral cable wrap". That's what it is called and it costs $3. Well, at least that's the going rate here in Ohio. Not hard to find.
Old Jun 11, 2003
SedanBoy's Avatar
thanks HYPR DRV!!!!
i figured i'd put them on before i got the springs installed......
GolNat
Suspension DIY
May 12, 2022 06:49 AM
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
edspyhill09
Jun 12, 2016 02:45 PM
bsmiley
Apr 27, 2015 01:27 PM
crazydragon
Nov 7, 2001 05:13 PM
