Question about my drop
Old Jun 3, 2003
texasric3r's Avatar
texasric3r is an unknown quantity at this point
I just lowered by car by 2". I had the rear camber kit installed and everything seems fine. In the back I have about 1 finger gap between the tire and the fender. However, in the front I have like a 2 finger gap between the tire and the fender. Any ideas why that might be? I'm gonna have the suspension place that installed the rear lowering springs and camber kit look at it, but I just wanted to see if you guys had any input.
Old Jun 3, 2003
reytito's Avatar
what springs do you have? it may not be the install job..could very well be the springs.
Old Jun 3, 2003
texasric3r's Avatar
I have dropzone springs part number DZ1013. They are supposed to be a 2" drop both front and rear. And I know lots of people saw stuff about how they dropzone suck for like handling and ride quality but suprisingly the ride isn't bouncy except over really large bumps and the handling is quite good.
Old Jun 4, 2003
02-4dr-civic's Avatar
02-4dr-civic is an unknown quantity at this point
i own a 4dr and have the same problem...i have eibach sportlines, and they are uneven... it was installed by a professional... eibach says it is sopose to be a 1.4" drop but the front is like a 1.75" and the rear is like a 2" in reality... i called eibach and they said that the civic has a weird bodyline so the rear will drop more. i'm going to get some adjustable for the rear and lift it a little higher to make it even...
good luck
Old Nov 7, 2003
Civic_Guy03's Avatar
Civic_Guy03 is an unknown quantity at this point
I need help. My drop is the opposite of everyone's car. The front has about a finger gap but the rear does not seem like it dropped 2". It seems like like half an inch drop. And yes, I am using the Dropzone springs. 2003 Civic Coupe.
Old Nov 7, 2003
Amplify's Avatar
Amplify is an unknown quantity at this point
good luck
Sportlines DO NOT drop 1.4 inches. That's the measurement BEFORE the springs settle. After settling, it's more around 1.75, so your drop is totally normal.
As for the uneveness, the problem might be the fact that Eibach doesn't differentiate between coupe springs and sedan springs. Other companies do and make their sedan springs to drop less in the back, so that it comes out even. Then again, I got Sportlines and my car doesn't seem noticeably uneven. It might be because I don't got a heavy system back there though. Do you? Maybe that's why your rear is lower.
The only thing I can think of to correct the unevenness is to get Koni Yellows and adjust the height to the higher setting in back. *shrugs*
Old Nov 7, 2003
Green Civic's Avatar
How long have they been installed? They might need to settle before the lowering becomes even.
Old Nov 7, 2003
It's been on like a month now. It still sort of looks like stock height. The car sorta looks slanted since the front is dropped. I can stick my whole fist between the gap and in the front there's no way.
EM_WON
Jul 22, 2015 06:49 PM
mrohitredd
Jul 21, 2015 09:26 AM
Bounddyy
19
Jul 20, 2015 02:42 PM
NoobyKid
Jul 13, 2015 07:53 AM
jody501
Jul 10, 2015 11:01 AM
