TEIN FLEX: finally!
Old May 29, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
TEIN FLEX: finally!
Ok guys, I was confused about all this TEIN FLEX not fitting our cars n stuff and how we needed to get RSX kits n all.
I emailed TEIN and here's what I got:
To David:
In regards to your question. We are currently in the final stages of
development for that particular kit. And is EDFC compatible and it will
be a
direct bolt on for your car. Please check back on our website for the
latest
release and updates.
Thank you for your interest in TEIN High Performance Suspension
Products.
Staff @ TEIN USA INC.
7631 Somerset Blvd.
Paramount, CA 90723
Phone: (562)633-7387
Fax: (562)633-7291
www.tein.com
I'm gonna wait for this! ^_^ hellya!!
Old May 29, 2003
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
I think the issue with the EDFC was that there wasn't enough room above the rear struts in the coupe.
Old May 29, 2003
§C§H§O§C§O§B§O
tein sales rep said the new edfc will be compatible...sure hope this person knows what he/shes talkin about... >_<
Old May 29, 2003
ViNRoCk8's Avatar
#1 S2000 Fan
I was gonna get a different coilover system but if we can use the FLEX with the EDFC i might have to get the tein's cause that EDFC is hot!
Old May 29, 2003
BLACKex613nin's Avatar
BLACKex613nin is an unknown quantity at this point
so when will this be coming out.. if its almost done.. and wont it cost like 2g's? does anyone have any idea?
Old May 29, 2003
HondaLuver's Avatar
Its a celebration bitches!
then what do we do if we get the rsx suspention? do we have to get new dampers? we should just still get the rsx ones and mod them... there is a member on this site that has them and the edfc and it works...
Old May 30, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
Hmm...
What could be the benefit of an EDFC? IMO, I think it's a waste of money. Why in the world would one need to constantly adjust the damper settings? Even the stiffest settings on the Flex is still streetable and comfortable.
I would just like to know why people see it as something they'd need.
Old May 30, 2003
§C§H§O§C§O§B§O
good point...no clue when the FLEX is gunno come out for our cars... but if it does it'll retail like 1600 for our cars, and 300 for the EDFC. I'm sure you guys have ways of getting better prices than that, anywhere sells cheaper than retail ^_^
but the RSX suspension is a problem...maybe we could just take the 01+ SI's rear brakes and bolt it on with no problems...dunno just speculation.
Old May 30, 2003
ViNRoCk8's Avatar
#1 S2000 Fan
I would have to agree with you. At first I thought it was worth the money because for some reason I thought you could adjust the ride height as well. I knew I was wrong after I read this Tein EDFC
Old May 30, 2003
robbclark1's Avatar
Retired suspension supermod.
Its for lazy people who don't wnat to get out of their car to adjust their dampening!
Old May 30, 2003
VNlilMAN's Avatar
The Standard One
ya lazy people with money...
Old May 30, 2003
TOOLOWCIVIC's Avatar
If u got the money get it if not then dont. U dont need it. People just get it to showoff cus it really isnt helping u out. With that money just get some airstruts with adjustable dampening. With that u can adjust dampening and ride height.
Old May 30, 2003
§C§H§O§C§O§B§O
which brand makes those?
Old May 30, 2003
All Eyes On Z
Laziness is EXPENSIVE!
Even for show purposes, I think it's even lesser of a priority.
But I don't get it... why would someone want to have this little box to adjust their damper? Laziness is only an excuse if you're rich. How often would one need to adjust their ride stiffness? To me, it just looks like one of those toys a kid plays with for a week and then tires of it and eventually finds no use for it later on.
Old May 31, 2003
can the Flex go lower then the SS?? how low can the flex go?
Old May 31, 2003
artychris's Avatar
artychris is an unknown quantity at this point
I'd have to halfway agree with you on that.
On the other hand, I have the SS and it is a pain in the **** to pop the hood and the trunk and play with different settings and sometimes if you miscount, then you gotta take it to the softest or stiffest and work your way back to the setting you want and the same applies for the other side. At least with the EDFC it takes the guesswork out of whether you're set on 12/16 or 13/16. And in a skidpad testing corner, a single click really does make a difference. I honestly just forget what setting I put it on and occasionally adjust it and mentally track it's responsiveness to corners. Now if the SS were compatible, I would get it specifically for easier tracking and compare different results and response for different corners.
Old May 31, 2003
All Eyes On Z
Why not just write it down just in case you forget?
Old Jun 1, 2003
tekgnosis's Avatar
Ask me about your mom.
I plan on making an EDFC.
sure, the display will suck, but for under $50/60 CDN, I should be able to get the same thing.
it's a really simple circuit: when you press up, turn the **** up. when you press down, turn the **** down. you just have to send out signals to each of the motors at once. not that tough.
if I could score a memory chip, then I could actually save the setting # it's on, and display it. not too bad.
and it's not just laziness...if I'm driving to work and see someone take the twisty roads, I'll follow them. I want a soft ride on the highway, but when I get off the highway, I want stiff suspension for the fun roads. I would look pretty damned retarded if I got out and adjusted all the struts...
Old Jun 2, 2003
RedDragon333's Avatar
yes they can but since the EM chasis setup isnt out yet its hard to give deff. numbers, i would have to say somewhere past 2ins since the SS go to 1.8
Old Jun 2, 2003
luvvegas777's Avatar
banned from avatar useage
luvvegas777 is an unknown quantity at this point
damm, bunch of ballers on this site, thought i was cool with the ss coilovers, now were talking almost 2k for the flex?
with that much i'd just get springs and save a little more for a turbo
Old Jun 2, 2003
§C§H§O§C§O§B§O
stock struts sux...that's all i gotta say...spending the money on SS or FLEX is well worth it...once my warantee runs out, they won't be replacing my struts for free nemore...can i complain to the dealer? or will they use the fact that I can GC coilovers against me?
Old Jun 2, 2003
All Eyes On Z
You modified your suspension so they won't cover it.
They'll blame the GCs about your struts and you can't prove them otherwise cuz anyone knows the stock struts aren't designed for a lowered car.
And even if you raised the car to stock height, the spring rates of the GCs would still cause premature wear on the struts.
Munzy
21
Oct 7, 2015 07:48 AM
Cam Diaz
Sep 29, 2015 07:17 PM
carid
Sep 28, 2015 10:13 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
TheRiddicles
Sep 21, 2015 01:28 AM
