camber kit install?
Old May 28, 2003
Purple2001Civic's Avatar
Purple2001Civic is an unknown quantity at this point
Unhappy camber kit install?
im lowering my car in a week or so and i was wanting to know if i needed a camber kit up front. im lowering the car about 1.5 inches. i have got a full kit ordered and will be in, in about two or three days. i know i will need the rear put in! i have a heavy stereo system in it. thanks for any info yall can give
Old May 28, 2003
Mikee's Avatar
Mikee is an unknown quantity at this point
u dont really need kit in the front its the back u need. i dropped 1.5 front and 1.75 in back. front is ok but the back tire is like this / \ so u will need it if u have a sound system in back cuz it drops more. every one useally gets rear spc kit. theres a group buy rite now.
http://www.7thgencivic.com/forums/sh...threadid=91546
Old May 28, 2003
civicvtec1ps's Avatar
Search and Learn
ya you will most likely need rear camber kit. go grab SPC one from groupbuy. 99.95 shipped.
Old May 28, 2003
jskull21's Avatar
jskull21 is an unknown quantity at this point
another question...
I got a 1.5 drop, with 17's and I knew just looking at it, that a rear camber kit was needed, with no money I waited a while.
My tires are spotted, so I went to the shop and he says he couldn't fit the rear camber, because there is no room in the wheel well. I really don't know too much about cars (still in the learning process). I'm assuming from the few threads I've read that he's wrong?
Help me out here.
Old May 28, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
yes you will!!! if you lower it then you will need one espically with a big box in the trunk. I have eibach sportlines with eibach camber kit.
Injen
Old May 28, 2003
flotsamm's Avatar
Originally posted by jskull21
another question...
Help me out here.
I bet he meant that your tires are too wide and he wasnt able to install a camber kit and do a proper alignment because the tires would scrape. Just guessing..
Old May 28, 2003
jskull21's Avatar
Your probably right, I wasn't really paying attention. He did tell me I should invest in some better tires, recommending Michelin. What is your suggestion?
Old Jun 2, 2003
well ive got the kit from spc but i ordered the full kit was just wondering if i needed to put the front in. i was going to put it in but if you all say i dont need it then i wont put it in. thanks for all the help on this
Old Jun 2, 2003
luvvegas777's Avatar
banned from avatar useage
luvvegas777 is an unknown quantity at this point
first what size are your tires? mine are 205/45/17 what i did was, got an air saw and cut the lip off the inner fender well, about an inch, so that will free up some room for your camber, if your droppin it about 1.5 and the shop says they can't then you need to find another shop.
i have ingallls front and rear, it's just a bolt kit for the front about 30 dollars, now the rear has urethane bushings so it squeeks over bumps:nothing you can do
other ways are to "roll" your fenders, i saw one guy get a baseball bat
and put it in between the tire and fender so that it bent that lip that i was talking about, thus rolling the bat.
i think the air saw is better
Old Jun 2, 2003
one last thing i noticed a lot of people saying how their rear end sagged lower than the front with springs, mine did the same i had h&r's took my box out and it still sagged even with proper alignment
so that's why i got tein ss coilovers
Old Jun 9, 2003
well ive got the car lowered friday and put the camber kits in the shop i took it to said i needed it in there so they could align. it right so im glad i did put them in . i have a spc camber kit and the bushings are squeaking too. starting to go away now. all i did was spray some liquid silicone on them so it will soften the bushings up. car rides good, better than stock. thanks for all the help yall have given me on this
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
CivicsClass101
Jul 9, 2015 11:14 AM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
