Suspension set up
Old May 22, 2003
l3lackstatic's Avatar
l3lackstatic is an unknown quantity at this point
Question Suspension set up
Alright heres the deal i got a 2001 civic LX coupe and i want to drop it right.... But i dont know jack **** about suspension or wat i need to drop it, so i was wondering if some of you pplz out there could help me by telling me whats a good setup thats fairly inexpensive say under 800 dollars i heard i could just get lowering springs but then i think ill need a camber kit along with that, then someone else told me i would need new shocks so if someone could help me I would be grateful Thanks
Old May 22, 2003
Weaponx12o's Avatar
if i were you, i would save up an extra 200-300 bucks and get true coilovers (ie- b+g's or teins). you wont have to worry about buying shocks since it is a full replacement of your stock suspension. however, you would still need to get a camber kit.
Old May 22, 2003
robbclark1's Avatar
Retired suspension supermod.
Please, please DO YOUR RESEARCH before you buy anything. Nothing is worse than a bad drop!! If i were you, save up another $500 and get true coilovers and a spc camber kit. If you can wait, the HR cup kit is supposed to come out soon. I do not suggest getting sleeved coilovers.
Old May 22, 2003
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
Quick fix at your current budget:
Goldline Springs
Koni Yellow
Alignment
Install
That would run you around $850ish installed.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
EdGasket
40
Nov 27, 2015 11:11 AM
Mr.Beefy
Aug 12, 2015 04:39 PM
Strycker
Aug 2, 2015 08:40 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
