Back is lower than the front....
Old May 13, 2003
hangoooknamja's Avatar
hangoooknamja is an unknown quantity at this point
Angry Back is lower than the front....
How do you fix the suspension defect in ride height? My back end is lower than the front end.
Do I need strut bars? What can I do to fix this problem?
I have Sprint 2.25 drop springs with Koni adjustable shocks, Ingel camber kit and a DC lower
tie bar.
Please help.
Old May 13, 2003
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
how much of a difference r we talking about on your car?
Old May 14, 2003
Weaponx12o's Avatar
yea, if its not much, then it's probably nothing. strut bars dont fix the ride height
Old May 14, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
1. Strut bars have nothing to do with adjusting the ride height.
2. It's probably the way the springs are made or...
3. The only other thing is that it could be your camber kit - providing you have one in the rear. If the rear wheels are facing inward noticably from the top of the wheel (cambering negatively), you can try to fix it a bit by adding more positive camber. This can slighty change the height of the car if you lower the arm which would make the wheel stand up more vertically, add positive camber and raise the height of the rear more.
Note: If you already got an alignment on your car, you'll have to get another one after messing with the camber. You should get an alignment after you are completely satisfied with you suspension set-up... meaning you won't have the need to adjust the height or the camber angle for a while.
Old May 14, 2003
DizWikedCivic's Avatar
if you can springs u cant do anything about it, the only thing you can do is get new springs or cut a coil off your old spring but u dont wanna do that
Old May 14, 2003
ASIANPRIDE's Avatar
GODLIKE
ASIANPRIDE is an unknown quantity at this point
Ok..if your *** is to low...what you can do with your Koni's is adjust the snap ring that holds your rear perch up.....(its the lil metal part on the strut that is in the groove that keeps your perch in place....) If you look on your strut body there is a second notch (groove) where you can put the snap ring...it's about 1 inch higher....you can us that and it will raise your car 1 inch higher or so....should take you 30 min to do all of it...no longer...the rears are super easy in install...
Old May 14, 2003
VNlilMAN's Avatar
The Standard One
ya you have konis, just set it to the higher perch
Old May 14, 2003
back is lower than the front...
How do I adjust the rear perch on my civic? Help please..?
Old May 15, 2003
ASIANPRIDE's Avatar
GODLIKE
OK...well I don't know if you are the right guy to be doing this job....did you install your KONI's yourself....for me it's really easy to do..cuz I have access to a lot of good tools that will allow me to install my backs in like 30 min.....
But for you this could take longer if you don't got the right tools.....first of all look at this picture....see there is that ring that is in the left notch......Now try and pop the ring out....IT WILL BE ****ING HARD...cuz its in there tight......pry it out but don't try and bend it.....
THEN MOVE THE RING INTO THE NOTCH ON THE RIGHT...you gain like 1 inch.....
GolNat
Suspension DIY
May 12, 2022 06:49 AM
mistermenphis22
Apr 3, 2016 08:06 AM
GolNat
Sep 10, 2015 08:25 PM
jdawgzcivic
May 20, 2015 08:14 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
