Problem with Tein spring
Old May 12, 2003
02quikcivic's Avatar
02quikcivic is an unknown quantity at this point
Just lower the 02 Civic. And I'm have some issue on the left front driver side. Did everything right to the point of installing. But can't figure out what is wrong. Everytime it roll, it making some clank sound. when you step on the brake you can feel it too when slow down. Anyone in here have an idea? And does tein have this problem? Or is it just Tein spring itself?....Please help if you can.
Old May 12, 2003
VNlilMAN's Avatar
The Standard One
"Everytime it roll" everytime you drive the car????
does it sound like some metal is hitting metal? it it when you go over bumpy road? cause it could be 1) spring isolators werent used 2) the top nut wasnt bolted down all the way 3) the top perch wasnt aligned right.
when you step on the brake you can feel it? feel what? steering wheel shakes?
Old May 12, 2003
All of the above question you ask...when step on brake, or when you just turn the steering wheel. Don't shake. But you can feel like the Metal to metal. When turn, you will hear. Clank, clank clank. But when you roll you don't really hear it.
Old May 12, 2003
Oh we double check the whole thing. We even did it twice. Took it apart and re-assemble it. Every bolt is bolt on to the max.
Old May 12, 2003
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
2002 civic? sounds like you aren't using the bearing ring-- read this:
http://www.7thgencivic.com/forums/sh...threadid=85403
it's very easy to forget to use the bearing ring on the 2002 model.. it almost looks like it's a part of the spring cap.
Old May 12, 2003
Thanks for the Info. I'll see what I can do with it. Would it also be the spring itself. I added an extra rubber to the bottom of the spring and it was better. but still when I turn the wheel without being in motion. It still make that clank sound. I was hoping not to take it apart again. But I guess I will have to.
Thankz Again...
Old May 12, 2003
VNlilMAN's Avatar
The Standard One
"but still when I turn the wheel without being in motion. It still make that clank sound"
its cause the springs themselves are twisting... if you jack up the car and turn the wheel it probably wont make that noise cause the springs arent preloaded much....
you probably didnt install the top rubber peice correctly. you know the rubber peice the spring goes into. one side should be narrower than the other. the end of the spring should go on the narrow side.
Old May 12, 2003
Ah, Gotcha. I see it now. thankz guys...you guys help alot.
cukaracha
Jun 7, 2015 03:32 PM
reqy
Jun 1, 2015 07:05 AM
elitezdc5
May 26, 2015 05:46 PM
cruisers10
May 12, 2015 10:46 PM
