rsx rear sway bar
Old May 8, 2003
SilverStreakEX's Avatar
Show me your titties, I'M RICK JAMES BITCH!!!
SilverStreakEX is an unknown quantity at this point
Question rsx rear sway bar
what exactly does this upgrade do for our cars? ive heard lots of people like them and stuff, but what exactly does it do for us? i installed it and i noticed that now my car is A LOT more bouncier. like when i hit a bump or something my rear end goes flying???
Old May 8, 2003
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
I don't know if I'm right or not but it may have something to do with the fact that each corner of the suspension is independent and not linked together. So each strut controls each wheel and corner independently, like if you hit a pothole on your front drivers side only that side will jump up. Each wheel can move up and down by itself and when you are cornering your wheels can hop because they lose contact with the ground.
When you use a anti-sway bar which I am guessing is under the car and not on top like a stru tower bar you are linking the two rear corners of the supension together and they can no longer act independently, because what happens to one corner will happen to the other since they are linked. So the benefits will be that when you corner, there will be no wheel hop or loss of traction, and steering will be more sensitive. But when you go over a speed bump or hit a pothole one corner of the car will bring the other up with it, that's why you feel like the whole rear of the car is "flying up."
Old May 8, 2003
dacivic's Avatar
dacivic is an unknown quantity at this point
WildRice you got it
Old May 8, 2003
eXNBP's Avatar
eXNBP is an unknown quantity at this point
The sway bar tries to balance out any movement from one side to keep the wheels planted on teh ground mostly. At least that's what I've experienced
Old May 8, 2003
VNlilMAN's Avatar
The Standard One
i'm tryna see if i want one or not too... my car is bouncy enough as is...
Old May 8, 2003
well, b4 this mod my car's suspension was basically stock and i loved the smooth ride. now after having it on for a few days, ive noticed that the ride is a lot more bouncier, well when im riding on smooth roads, its fine. but when the road is the least bit uneven (any bumps or anyhting) the rear of my car bounces like hell.
Old May 8, 2003
Slumpert's Avatar
Slumpert is an unknown quantity at this point
Did you install the Stock RSX one or the Beefier Type S one?
The 19mm one seems to be best for the stock rear-end from what I have read.
Just my 2cents
Slump
Old May 8, 2003
i got the huge type s one. its A LOT bigger than stock
Old May 8, 2003
civicvtec1ps's Avatar
Search and Learn
Ya type s = 19mm our stock ones are =13mm
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Marco83
Oct 13, 2018 10:13 PM
GotSiR
Jun 23, 2016 04:06 PM
muniorbust
33
Aug 31, 2015 08:59 PM
