camber kit?
Old Apr 24, 2003
03CIVICEX's Avatar
03CIVICEX is an unknown quantity at this point
camber kit?
what does it really do and whats the best brand and how much??
thanks
-keviee
Old Apr 24, 2003
CivicBR900EX's Avatar
Master
CivicBR900EX is an unknown quantity at this point
By lowering your car with performance springs, your camber on the wheels are usually negative. Stock rear camber is already negative, means the upper port of wheel and pointing towards the car and look a lil bit slanted. When camber degree is 0, means the wheel is upright, not slanted. Negative camber improves cornering but however alos can produce uneven wear on your tires.
I have lowered my Eclipse, EX, WRX and EX, and never got camber kit, becuz I didn't need them. The slight negative camber were just fine and if you have performance tires, they should last somewhat longer than your stock tires. Check tirerack.com, they sell Eibach camber adjustment kit. Installation for camber kit is about one hour of labor charge.
Old Apr 24, 2003
Master
Check out discounttire and tirerack.com both have some info about camber, toe-in etc.
Old Apr 24, 2003
pdubbz3for10's Avatar
pdubbz3for10 is an unknown quantity at this point
i bought the SPC rear camber kit and installed them myself. takes about an hour. but to get the alignment, you have to take it to a shop.
Old Apr 24, 2003
robbclark1's Avatar
Retired suspension supermod.
Can we please create a whole new forum for the quesion of "what is a camber kit and what is the best brand?" Oh pretty please!!
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
