Sedan Springs w/stereo??
Old Apr 22, 2003
Cokafka's Avatar
Cokafka is an unknown quantity at this point
OK I have searched. Are there any springs (not coil overs) that can handle a persons worth of stereo equipment in the trunk. I had goldlines and they said that "there spring rates were not designed for extra weight." I am thinking to myself WTF I can't have two people in the car. The equipment is located mostly to the front most part of the trunk. All I want is to lower the car to lose the gap with out sagging, is it possible???
Old Apr 22, 2003
MattC1's Avatar
MattC1 is an unknown quantity at this point
I have 2 12's in a heavy box and have no sagging I am riding on Koni's and Neuspeed race, you might want to replace your shocks that is the cause of sagging most of the time.
Old Apr 22, 2003
jeffschaid's Avatar
jeffschaid is an unknown quantity at this point
Sedan Springs
Was your vehicle "sagging" in the rear with Gold Line springs? If so, please let us know. We would be more than happy to address this matter with you.
Regards,
Gold Line Products
877-671-9752
Old Apr 22, 2003
Cokafka's Avatar
I was in contact with your company already, I should have saved the emails. I was angry about the answer I received so I sold them.
Old Apr 22, 2003
vino's Avatar
vino is an unknown quantity at this point
does any1 have pics of the goldlines on a sedan?
Old Apr 23, 2003
jeffschaid's Avatar
Sedan Springs
I'm not sure who it was that you talked/wrote to but, there is not a company in this industry that offers better customer service than Gold Line. I'm sure that anybody on this forum who has dealt with Gold Line would agree.
However, regardless of which springs you use, if you pile stereo equipment into the trunk of the vehicle the rear ride height "will" be adversly effected. Your only option is going to be coil overs. Coil overs will fix that issue due to the fact that the spring rates are entirely too high and that you can adjust the ride height to compensate for the additional weight.
Old Apr 23, 2003
VNlilMAN's Avatar
The Standard One
ey whussup jeff, your back... how come your not using the other sn 'goldline'?
Cokafka, if you HAVE to go with springs.. best best is neuspeed sports for sedan... the rear will probably be lower due to the extra weight but it wont be as badd as it was with goldlines cause goldlines springs are on the softer side and neuspeed are on the stiff side...
you can also get koni yellows. they have an adjustable rear perch. you can set it to normal or .5-1" higher. setting it at the higher clip should even out the drop..
Dave Brabant
20
Oct 6, 2015 12:44 AM
pfwel1977
Sep 10, 2015 02:16 PM
Ultra Havoc
Sep 9, 2015 10:58 PM
Josh 1973
Sep 7, 2015 10:10 AM
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
