Full Coilover System - Adjusting
Old Mar 19, 2003
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
Which coilover system do you have and how easy is it to adjust the system? Please be descriptive of what you have to do...I live in CT so depending on weather, depends on what height I want my car...
Thanks
Matt
Old Mar 19, 2003
civicvtec1ps's Avatar
Search and Learn
i have tein ss
very easy to adjust height. all you really need to do is take out tires. and use adjust tool that came with tein ss , and adjust height.
takes about like 5 mins per wheel.
Old Mar 19, 2003
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Exclamation it's not that simple
yea, 5 mins to adjust, but you have to add jacking up the car, jackstands for safety, taking the tire off, and all the above in reverse after the adjustment.
It would take you probably an hour tops to adjust all 4 corners, then you have the problem of wheel alignment changing with the ride height. IMO, too much of a pain in the butt if you want to adjust height from day to day.
FYI, it takes me about 1/2 hour per end to adjust my B&Gs. I'm using a floor jack (not the OEM spare jack, add another 1/2 hour per end if you're going to use that emergency jack).
If you want to adjust your height quickly, then I would suggest an airbag system.
Old Mar 20, 2003
MIT's Avatar
MIT
MIT is an unknown quantity at this point
so if like Tein SS, to adjust height, do you need to adjust the damper force too? can anyone explain to me what "damper force" do?
thanks
Old Mar 20, 2003
Weaponx12o's Avatar
i think the damper force is the same thing as damper settings. it's to adjust how stiff or soft you want your ride to be. i have B+G's and they're self adjusting. so i cant adjust how stiff i want the ride to be. adjusting the ride height on the B+G's is pretty much the same as TEIN's. you just need that tool.
Old Mar 20, 2003
DizWikedCivic's Avatar
well i dont have full coilover, only got sleeve coilover and it take about 10 mins to adjust each wheel, cuz i gotta run over a brick cuz my jack wont fit under my car, take out the wheel and etc
Old Mar 21, 2003
VNlilMAN's Avatar
The Standard One
ya its definitely something you wouldnt want to do everyday but how many times are you going to adjust it anyways? not much, probably less then 7 times the whole time you have them.
Old Mar 21, 2003
sc1golfr's Avatar
sc1golfr is an unknown quantity at this point
I also have B+G's, the dampening adjusts itself and the ride is GREAT. as for the height, they spin just like most other coilovers, just like Tein...I didnt have the tool though, i didnt know there was one, its still able to be done without it, but its a big workout on your forearms, mine hurt a lot the next day.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
HX
Dec 22, 2001 02:36 PM
Dagooseisloose
Bolt-on Engine Performance
Dec 7, 2001 02:56 PM
deception420
Dec 6, 2001 02:31 PM
duyaknow
Nov 23, 2001 07:28 PM
