--HELP-- SPRING problem
Old Mar 6, 2003
Nuts's Avatar
Nuts is an unknown quantity at this point
ok i just installed my neuspeed sports and i'm having problems with the rear. heres the problem.....everytime the car bounces i hear a scraping sound coming from the rear of the car. i don't think its scraping the ground or anything cuz its not that low. i think when it bounces my tires are hitting the rear fender piece (the top of that). i dunno if i messed up the rears somehow but i have 215/40/18 tires. i have a rear camber kit thats alligned. should i put a negative camber in hte rear so it doesn't hit that? i have a 1.5 finger gap in hte front and a very snug 1.3 or so finger gap in the rear. whats up. i have no system. could i have put a piece from hte strut assembly in hte wrong place. whats running a rear camber with a drop? and whats up.
Old Mar 7, 2003
Nuts's Avatar
oh and i don't think my rear springs are upside down even tho the word neuspeed on hte spring read upside down the tighter coils were on the bottom. the smaller more spaced out coils went at hte top and slightly larger, closer togerher coils went at hte bottom.
Old Mar 7, 2003
flotsamm's Avatar
Are the outer edges of your tires rubbed off from scraping the fender? When you installed the rear struts after putting on the springs, did you make sure that the little dot on top of the strut mounting bracket were facing inwards?
Old Mar 7, 2003
VNlilMAN's Avatar
The Standard One
did the drop even out? cause i remember you said you had 0 on the drivers side and 2 finger gap on the passenger side.. or was it cause you did forget that peice?
well try pushing down on the car, see if the tire rubs against the fender lip. if it does, i would just roll it a little.
Old Mar 7, 2003
djmota's Avatar
heres a good way to load up your suspension in the rear and see if it rubs. Get a jack...not the stock one... and use one of the front jack points and pump away. as you raise this corner it will put more wieght on the rear oppisite corner. Raise it up and take a look. If it rubs you will either have to turn in your rear camber kits evenly on both sides until it does not rub, and rotate them more often. or get smaller tires that will clear.
reqy
Jun 1, 2015 07:05 AM
vtec_concept
May 24, 2015 10:27 AM
cruisers10
May 12, 2015 10:46 PM
oneheadlight
Apr 29, 2015 11:30 PM
Flatlander
Nov 16, 2001 05:38 PM
