camber kit installation?
can someone post a diy for a camber kit installation? (front and rear) the thread on the diy page isn't working. thanks [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
it pretty easy to install camber kit, just take out ur stock camber and replace it, all you need is a jack, jackstand, and socket wrench. and the for the rear one of the nut doesnt turn it like weld on, so if you have trouble getting loose your turning the wrong nut
Quick instructions:
On the fronts pull off the top bolt behind your wheel on your strut and replace with the adjustable one. Don't mess with it just tighten it up.
the only point on the rears is take off the stock one and adjust the replacement to the same length and install. then drive it to an alignment shop and have them take care of the adjustments.
Bill in San Jos
Jul 10, 2015 12:32 PM
CivicsClass101
Jul 9, 2015 11:14 AM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
