my negative camber w/ goldlines
Old Oct 17, 2002
VtecPIMP218's Avatar
VtecPIMP218 is an unknown quantity at this point
i drive a 01 sedan w/ goldline springs and spc camber kit. I have 205-45-17's on my car. i went to get an alignment today and i found out that have a negative 3 camber on my back tires!! i also have no gap whatsoever in the back. i was told that to get an alignment i needed to lift the back more...he also said that i should go with a 1 inch drop on the back...i know my tires are thick but what should i do? i just bought 4 new tires..45 series...and he suggests i get the pro kit for the back springs...would there be any problem w/ this setup: goldlines up front and pro kit in the back??? also ...is the rear springs for the coupe the same drop? could i get the rear goldline springs for the coupe, or are they the same??? what should i do?? i need my new tires to last..?hopefully the pro kit will help? someone help me!!!!![IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
John
Old Oct 18, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
205/45 is a relatively thin tire, compared to the 215s and 225s some people use.. I don't see how it couldn't be done, unless you have a very small offset on your rims. just roll your fenders
Old Oct 18, 2002
[IMG]i/expressions/face-icon-small-confused.gif[/IMG] i already rolled my fenders..i got the shop to do that..they cut out the inner fender and sealed it so it wont rust.....if he adjusts it its only going to have a .5 diff in camber..so its going to be 2.5...i need to lift up the back..the tires tuck in the wheel well....and i need an alignment...so will the eibach pro kits on back work???
Old Oct 18, 2002
VNlilMAN's Avatar
The Standard One
ya goldlines have a smaller gap in the rear then the front. thats why i only recommened neuspeed sports for sedans. i think i remember you asking if they would rub or not... prokits would work but the drops not going to be pretty and why spend $200. what you could do it add a "spacer" in the rear springs.. not sure if you installed the springs yourself but... theres a rubber peice on the top perch, familyguy bought another one and put it on the strut to make the rear a little higher. i think it raised the car about .25".
Old Oct 18, 2002
Mex's Avatar
Mex
I remember I forgot to put the spacer back in when installing my B+Gs.. you don't have to disassemble the strut to add it, just remove the top bolt, slide it in, and put the bolt back can be done without jacking up the car.
Old Oct 18, 2002
vnlilman...no i didnt install the springs myself...and where would i get a spacer?could i get 2 so it would lift it half an inch? why do you say the drop isnt going to be pretty with the pro kits on the back and goldline up front??i have bout 1-2 finger gap up front..and i think that the back will be even with the front b/c my tires tuck in the back, and how much does the spacer thing cost??
John
Old Oct 18, 2002
VNlilMAN's Avatar
The Standard One
look at part #12($8 there), familyguy put it in between #9 and #13. not sure if 2 of them would be safe. well it might look ok cause i know on a coupe the prokit gives you like a 3 finger gap. maybe on sedan you get 2.
Old Oct 18, 2002
GoldLine's Avatar
GoldLine is an unknown quantity at this point
Call Gold Line @ 877-671-9752. Explain what is happening and I'm sure we can determine (and fix) the problem. You always want to call the manufacturer when you have a problem like this. You may have the incorrect kit for your specific vehicle. Also, the SPC Alignment kit offers up to 4 degrees of adjustment. This will fia (any) alignment issues "if" installed properly. Please give us a call asap.
Regards,
Jeff
Gold Line Coil Springs
877-671-9752
Old Oct 18, 2002
[IMG]i/expressions/face-icon-small-smile.gif[/IMG] I just got off the phone with jeff from goldline! It seem that i MIGHT have the coupe springs on the rear...so he is sending out a new set of rear springs for my sedan!! i also forgot to mention i have a box in the back with 1 12" and an amp attached to the box. it seems that this might be weighin the back of the car down, since it sits behind the springs! he is sending me the springs today..should be here next week..i hope this fixes it...the people from goldline have the BEST customer service!!! ill keep you guys posted
John
Old Oct 18, 2002
TOOLOWCIVIC's Avatar
Goldline has the best customer service.
Old Oct 18, 2002
Mex's Avatar
Mex
Jeff is the man!
btw, the spacer is part #2 on that list
Old Oct 18, 2002
VNlilMAN's Avatar
The Standard One
ya goldline does have the best customer service. i assumed you had sedan springs so i didnt even think goldline could do anything for you in that case
Ricerman
Aug 6, 2010 10:51 AM
greatcasa
Aug 26, 2003 08:16 PM
DoYung
Feb 24, 2003 12:37 AM
VtecPIMP218
Sep 16, 2002 11:25 PM
Red2k3Civic
Jun 13, 2002 03:29 PM
