Question for those who bought RSX rear sway bar....
Old Oct 11, 2002
sumama's Avatar
sumama is an unknown quantity at this point
Has anyone bought it from the Acura Dealership? The guy at the dealership said it comes with the bar only. If you bought the sway bar somewhere else (like hondawerx.com) did it come with nuts and bolts or bushings? or just the bar itself?
Old Oct 11, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Bought mine from Hondawerx. It came with the bar, bushings, and brackets. No nuts or bolts.
Old Oct 11, 2002
solar's Avatar
solar is an unknown quantity at this point
Does this Sway Bar from a RSX really bolt up to a stock Civic? I read a earlier thread that said HondaWerks sells the bar and bushings, if this is true, does it really make a differance in handling?
Old Oct 11, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Quote
[hr]Originally posted by: solar
Does this Sway Bar from a RSX really bolt up to a stock Civic? I read a earlier thread that said HondaWerks sells the bar and bushings, if this is true, does it really make a differance in handling?[hr]
Larger rear anti sway bars will definitely improve handling by decreasing body roll. Everyone seems to like them. Your stock rear anti sway bar is 12mm long. The one off the RSX Type S is 19mm, and the Type R is 22mm.
And if you've not bought parts from a dealer, expect to pay for the extra parts it doesn't come with. This happens with mostly anything you buy from a dealer. If you buy a headlight, fender, or a trunk lid, you're not gonna get the screws, just the headlight, fender, and lid. No parts to bolt it on. You have to order those, too.
Old Oct 12, 2002
Quote
[hr]Your stock rear anti sway bar is 12mm long. The one off the RSX Type S is 19mm, and the Type R is 22mm.
[hr]
Oops, we all know you meant to type diameter. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
mistermenphis22
Apr 3, 2016 08:06 AM
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
Thees1
Apr 14, 2015 08:23 AM
Firefly
Nov 28, 2001 06:13 PM
