help with skunk 2 coilovers
Old Sep 21, 2002
TuffVietta's Avatar
TuffVietta should not be trusted
i recently had a shop install skunk2 coilovers for me and the ride quality is pretty good. however, i noticed a clanky noise whenever i turn. is there anyway to fix this? i know a girl who had the same problem with skunk2 coilovers but when she got her bodykit and raised her car a little bit the problem went away. also i noticed that the steering has gotten stiffer. i dont know if this is due to the extra weight of the rims that i also had put on today or if its because of the coilovers. is there any way to fix this problem as well? any responses would be greatly appreciated. thanks in advance.
Old Sep 21, 2002
JoeB16's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way Galaxy
JoeB16 is an unknown quantity at this point
they will settle as you put miles on them. i have origional skunks, and they did the same thing.
Old Sep 21, 2002
TuffVietta's Avatar
thanks for the response joe. i was wondering if ur talking about the noise or the stiffness of the steering. i can live with the stiffness but the noise really annoys me. i read somewhere on this forum that its because of the control arm. u can read about this here.
Old Sep 21, 2002
JoeB16's Avatar
stiff is how skunk springs ARE. the noise is the spring moving around on its perch. try adjusitng the height and see if that helps.
Old Sep 21, 2002
AceKicker's Avatar
AceKicker is an unknown quantity at this point
hey tuff jsut liek joe said it is beacause they are new and trying to settle i have them too. to avoid the noise jsut turn ur radio up that is what i do sometimes but it will go away ok.
Old Sep 21, 2002
platinumx310's Avatar
platinumx310 is an unknown quantity at this point
MAN, MY SKaNK2 COILOVERS ARE HORRIBLE. THEY ARE BOUNCY LIKE A MOTHER.
AT FIRST IT WAS OK...BUT JEZUS MAN, MY CAR IS LIKE A TRAMPOLINE !
U THINK I GOTTA REPLACE THE SHOCKS FOR THESE ? ANYTHING ?
Old Sep 21, 2002
AceKicker's Avatar
well if u lower the coils all the way down then it is going to be bouncy as he11 but i raised mine tot he top it still looks lowered and the ride is much better. i had mine lowered all the way for a few months then i blew my front right strut so im waiting to get the money and either get a new strut or konis or a full coilover kits.
Old Sep 21, 2002
TuffVietta's Avatar
hey acekicker, how long does it take b4 the sound goes away? thanks.
Old Sep 21, 2002
AceKicker's Avatar
well it took about four days BUT the other week i got bored when i had my car jacked up i messed with the rear coils and now they are started to squeak again. i think that they are squeaking against the sleeve part so im going to shoot some wd-40 on there tomorrow. but my front dont squeak just the back right.
Old Sep 22, 2002
TuffVietta's Avatar
thanks for the response acekicker. im not sure if we're talking about the same noises. mine doesnt make a sqeaking sound...it makes a clanking sound like metal pots hitting each other except for not as loud. so i dont think its the springs settling in but the control arm rubbing against another metal thing (i dont know what its called). the stock ones were good in the way that they had bearings to prevent the rubbing but the skunk2's designed is flawed in the way that there is nothing to allow the control arm to rotate freely. as squeaking is concerned, mine dont squeak at all.
Old Sep 25, 2002
TuffVietta's Avatar
another problem i'm having with the coilovers is that whenever i complete a right turn, the steering drifts to the right and when i complete a left turn, the steering drifts to the left. this problem annoys me the most since i have to continually correct the steering while on a straight road. do u guys think that the problem will be fixed if i get a wheel alignment??? thanks in advance.
Old Sep 25, 2002
VNlilMAN's Avatar
The Standard One
its possible that it might be an alignment thing, but my guess would be it only leans one way rather then both left/right... not to scare you or anything but maybe its something else such as a broken cv boot or tie rod end. maybe try jacking the front of the car up and see if the wheels have play going from left to right(facing the tire). i dont even know if it does normally tho..
Old Sep 28, 2002
TuffVietta's Avatar
i found this link on another post.
http://www.energysuspension.com/sboots.html
i'm pretty sure this will solve my problem of the noise but i'm not sure which size to get the coil isolators in. anyone know which one would fit? the stock one is too big for the skunk2 coilovers and it'll just slip off. thanks for all your help.
Old Nov 11, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
Quote
[hr]Originally posted by: platinumx310
U THINK I GOTTA REPLACE THE SHOCKS FOR THESE ? ANYTHING ?[hr]
Yup, you cannot mod one thing in the suspension and expect it to be fine. How many people like doing things cheaply?
Old Nov 11, 2002
VNlilMAN's Avatar
The Standard One
*raises hand* me... [IMG]i/expressions/laugh2.gif[/IMG] so ya you know i'm broke.. damn only if i had money
Old Nov 11, 2002
ViNRoCk8's Avatar
#1 S2000 Fan
I was thinking on getting these coilovers.....so I guess you guys would think that isn't a good idea.....how low did you have the drop set?????
Old Nov 11, 2002
JumpingBean's Avatar
JumpingBean is an unknown quantity at this point
I got skunk2 coilovers and konis. I havent had any problems. I even installed them myself. First time ever. I love em.
GolNat
Nov 27, 2018 03:32 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
