Taking apart springs to grease and reinstall..
Old Sep 16, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
as many of you know by now there has been a nasty clanging noise associated with B+G coilovers. I got an allignment and camber adjustment right after I installed them. what i'd like to do now is grease up the front.. maybe even the rear too. my question is, if I mark a straight line at the top of the front spring/strut, and line them back up that way when I install them, would I be okay as far as the allignment goes? if I test drive the car and it drives straight when the wheel is straight, can I be certain my car is 'alligned'? also I don't want to screw up the camber.. the rear I can take apart without messing up the adjustment, but the front bolt is eccentric. if I put the bolt back exactly in the position it's resting in now, would the camber remain correct?
Old Sep 16, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Quote
[hr]Originally posted by: Mex
if I mark a straight line at the top of the front spring/strut, and line them back up that way when I install them, would I be okay as far as the alignment goes?[hr]
I think you should be ok, the ends of our springs are ground flat, so I don't really think spring/strut alignment is even a factor.
I've noticed the spring noise is a little bit louder now. I might take mine apart again before I get the alignment. Maybe add some grease between that rubber cushion and the red spring separator. IMO, the double spring design is flawed. [IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Sep 16, 2002
Mex's Avatar
Mex
the other day I sent an email to B+G asking about a new design for the seperator cup.. we'll see what happens
GolNat
Suspension DIY
May 12, 2022 06:49 AM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
reqy
Jun 1, 2015 07:05 AM
oneheadlight
Apr 29, 2015 11:30 PM
