install rear upper tie bar
Old Aug 20, 2002
Wojo's Avatar
Wojo is an unknown quantity at this point
Where exactly do i install this i bought a front and rear upper tie bar for better stability. i know where to install the front but not the rear. Its a rear upper tie bar.
Old Aug 20, 2002
VNlilMAN's Avatar
The Standard One
tie bar or strut bar? if its the strut bar, look right behind the seats in the trunk... its all the way in the corner...
Old Aug 21, 2002
Bartkat's Avatar
It mounts to the rear shock towers that are sticking up inside the trunk on each side behind the rear seat. This one goes on just like the front one except it only has two bolts instead of three. It's a little hard to work there due to confined space, but you can do it with a little patience. Fold the rear seats and that gives you a little better access.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Bar_location_behind_rear_seat_C.JPG (30 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Shock_attachment_left_side.JPG_C.JPG (37 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Shock_attatchment_right.JPG_C.JPG (24 Kb)
Old Aug 21, 2002
Wojo's Avatar
sweet shouldnt be too tough then thanx
bryden13
May 18, 2015 12:22 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
BiGbRoWn
Nov 21, 2001 06:17 PM
PlatnumBomb
Nov 9, 2001 01:11 PM
