ATTN: ppl w/ neuspeed sport springs
Old Aug 16, 2002
viciousvolpe's Avatar
viciousvolpe is an unknown quantity at this point
ok...anyone w/ neuspeed sport springs go outside and look
i think they put my springs on wrong
my drive side squicks real bad
how r the words neuspeed on ur springs
front drivers side is facing towards the rear of the car
front passanger is facing towards the front
rear drivers side is facing towards front of car
rear passanger side is upside down facing front
help me out guys cause i think they f'ed up....it also doesnt seem like the rear dropped the same on both side
please please help me quick cause i paid 200 bucks for install and if they f'ed up theres goin be h*ll to pay[IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Aug 16, 2002
actually the rear drivers side is the upside down one and its definitly upside down...i jacked my car up to check..im goin check each spring to make usre they rnt upside down
Old Aug 16, 2002
VNlilMAN's Avatar
The Standard One
the direction of the labels shouldnt matter when installing springs. n yes the label on the rear should be upside down, even an idiot cant get that wrong since the spring only fits in one way there.. the front however, its possible to install it both ways. i always thought it was tighter coils on the bottom but someone said they called neuspeed and they told him the tighter coils are supposed to be at the top. i'm sorry but whoever told him that is an idiot. also you'll notice a groove on the bottom perch(where the spring sits) and the end of the spring should be near it
Old Aug 16, 2002
VNlilMAN's Avatar
The Standard One
as for the squeeks i'm not sure, maybe try spraying wd-40? or you could take it back and they'll probably tell you its cause they have to settle(mine never made those noises). i had a 'pinging' noise everytime on got in the car but no squeeks.. someone else here had a problem with their goldlines squeeking... not sure whats goin on here...
Old Aug 16, 2002
im goin call and have them fix the back one
and see what is goin on w/ the front drivers side(the sqeaking)
Old Aug 16, 2002
VNlilMAN's Avatar
The Standard One
uhm.. maybe you didnt read it but the rear coils only go in one way and its very hard to get it wrong. the neuspeed logo on mine were upside down too.
Old Aug 16, 2002
the tight coils rnt on the bottom
Old Aug 16, 2002
VNlilMAN's Avatar
The Standard One
on the rear? are you sure? the bottom ones should be touching each other... if you are right then i suggest you not even go there cause like i said, even an idiot cant get that wrong...
Old Aug 16, 2002
eddie's Avatar
eddie is an unknown quantity at this point
I have neuspeed spot springs too and my rear springs are upside down(meaniing the words are upside down) . I was told that was the only way it would fit. I have no problems in the back. As for the front, i had it the right way(tighter coils on the top)..but i had a clickin noise everytime i go at low speed or turnin my steerin wheel at low speed. So i went ahead and did the front springs right side up (tighter coils at the bottom) and it still makes clickin noise. Does your front do that too?? I called neuspeed about the clickin the noise and my springs being rightside up. They said the springs are okay if it's rightside up because it fits optimacally or something. As for as the clickin he will get back with me. If the springs break i have fulll warranty so it doesn't matter.
Old Aug 16, 2002
VNlilMAN's Avatar
The Standard One
when did you get the springs installed? cause when i first got them i got a clicking/pinging noise too. not sure when the car was in motion cause of my system but i heard it everytime i got in my car... after a month or two the noise stopped...
Old Aug 16, 2002
eddie's Avatar
i got my springs install 2 weeks ago. And the clickin still exists
Old Aug 17, 2002
VNlilMAN's Avatar
The Standard One
ya mine went on for like a month or two...
Old Aug 17, 2002
only my front drivers side makes the sqeaking/clicking noise
the backs make noise too but the front is real loud
Old Aug 18, 2002
RSXtypeIvtec's Avatar
Su Mo
i just installed my neuspeed sports last week too, and oh man does my front drivers side AND passenger squeak so much!! its unbelievable how much it squeeks, only at low speeds. yes the rear coils are suppose to be upside down....only way it can fit.
it scares the cr@p outta me every time i turn. hopefully it will go away like other peeps have said.
Old Aug 19, 2002
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
Front: tight (dead coils) on top
Rear: tight (dead coils) bottom
Note: the front springs might fit with the dead coils on the bottom but if you try both ways, you'll notice that the strut piston sits centered when the spring is installed with the dead coils on top. However, if you flip the spring over and have the dead coils on the bottom, you'll notice that the strut piston sit off center inside the spring. You want the strut piston to be centered as much as possible.
Also, need to make sure that the small hole in the upper metal spring perch is facing inward toward the engine on both sides when the strut assembly is installed.
Also, gotta put that coil sleeve around the bottom spring coil. It will prevent unnecessary noise.
In addition to all this, have the dust cover/boot cut off the front bump stop so that you just have the bump stop installed. Don't worry about ruining the strut piston 'cause it's all sealed and won't allow dirt/contaminants into the shock.
Hope this all makes sense cause it has worked marvelously for me.
TJ
Old Aug 19, 2002
loki's Avatar
loki is an unknown quantity at this point
ok, so the clicking noise is normal? i was afraid they installed it wrong or i might need cambers or an alignment already. i really don't know jack about suspension. hopefully the clicking noise stops sooner than a month or two. it's really annoying! sorry, i just had to vent out my frustration.
Old Aug 20, 2002
urs probably goin need camber kits
im waiting for my rear one to come in...front is on though
Old Aug 20, 2002
loki's Avatar
ok i'm a little confused. i thought i just needed an alignment? can anyone clarify this for me. if i need cambers, which one do i need? i'm under the impression that there are different kinds out there, not just brands, but different degree or something. thanks in advance.
Old Aug 20, 2002
VNlilMAN's Avatar
The Standard One
well you need a camber kit to get proper alignment... our rear control arms arent adjustable so you cant fix the camber without the camber kit. there are three brands out so far, ingalls, spc and eibach... as for difference, only difference is the degree you can change the front. the front camber kit only replaces a bolt.. you need 1 to change to 1 degree and 2 to change up to 2 degrees.
Old Aug 20, 2002
sumama's Avatar
sumama is an unknown quantity at this point
Quote
[hr]Originally posted by: VNlilMAN
i had a 'pinging' noise everytime on got in the car but no squeeks.. ...[hr]
are you talking about a 'pinging' noise when you close your door? I have neuspeed sport and whenever i close my door kinda hard, my suspension (probably my springs) makes that noise. if it is the same problem u had, does it ever go away after a while?
Old Aug 20, 2002
VNlilMAN's Avatar
The Standard One
i got the noise whenever the car moved. i noticed it mainly when i step in the car. but ya now it doesnt make that particular noise after 2 months.
Old Aug 20, 2002
Su Mo
whoa after 2 months!!
i havent even had them for 2 weeks yet and i cant stand it
2 months is pretty long, hope mine doesnt last that long
Mike04Civic
Mar 5, 2006 01:10 AM
WannaBFast
Apr 8, 2004 05:12 AM
XxJDMCivicxX
19
May 28, 2003 09:16 PM
02NBPcivicEX
South Cali
Nov 12, 2002 08:40 PM
ChEe12iO
Apr 2, 2002 08:49 PM
