Sway bar info
Old Jul 6, 2002
Goober's Avatar
Goober is an unknown quantity at this point
Sway bar info
What is the size of our front sway bar. I have a 2002 lx sedan (canadian version).
I know I can upgrade my rear sway bar by putting a rsx-s and going from 12mm to 19mm.
Can I put the front swaybar from a rsx-s onto my car? Would it be better to do both or just the rear?
Old Jul 7, 2002
CapYoda's Avatar
Escaped Convict
you have a 2002 lx. the rear is 13mm.. its better than 2001 lx which has none.. heh. or 2001 ex too. we had a 12 mm...
just the rear is fine I think.
u shouldn't need to bump up the front or decrease it... the front is 25.4mm
Old Jul 9, 2002
iamfob's Avatar
iamfob is an unknown quantity at this point
ok my friend is selling his RSX sway bar. he is not sure if it is 19mm or 23mm. his car is not the Type S...it is the premium model
i have a 2001 Civic LX Sedan (canadian model) so i have no sway bar front and rear right?
or should i get front and rear sway bars from a RSX-typeS instead???? pls help me out.
thanx
Old Jul 11, 2002
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: Goober
Can I put the front swaybar from a rsx-s onto my car? Would it be better to do both or just the rear?[hr]
One guy here put on the JDM RSX sway bar on the rear. It's 22mm. He said that the car felt neutral. He does autocross too, so I believe him. You could do that. I'm not sure if the front sway bars from the RSX fit on the 7th gen Civic? I hear people saying no though.
Quote
[hr]Originally posted by: iamfob
thanx[hr]
You have no sway bar in the rear only. In the front you do have one. If you want to get a rear sway bar then you'll have to do DriftR's DIY: DIY: 2001 DX LX sway bar I'm planning to do this as well. I'm planning to get the Progress rear sway bar. It comes with an integrated tie bar. People say that you need to reinforce the rear chassis if you go with a thick sway bar like that. This is what I will buy. Oh yeah, it's 22mm. One other tidbit of information that might be useful is that the front swaybar is hollow while the rear is solid. This means that the thicker sway bar in front may provide just as much anti-sway tension as the rear sway bar. To get the exact idea you need stiffness calculations, weight distribution, and sway bar shape. Anyway...
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Marco83
Oct 13, 2018 10:13 PM
muniorbust
33
Aug 31, 2015 08:59 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
