Torque of front and rear shock tower nuts after new springs
Old 06-29-2002
skitzo's Avatar
skitzo is an unknown quantity at this point
I had a eibach sportline kit installed a while back and was putting on a front sway bar and noticed that the torque on the nuts was at about 50 ft/lb. That doesn't seem correct, did they over torque the bolts or do you have to torque them down tighter with a different set of springs?
What about the rears, I haven't checked them yet but should they be torqued a bit tighter? All the searching I did came up with 33 ft/lb for the front, but didn't specify if that was with or without stock springs. what about the rears?
Old 06-29-2002
The Standard One
VNlilMAN's Avatar
if its 33lbs/ft with stock it should be 33lbs/ft with any other set of springs
Old 06-30-2002
TEKNIQ's Avatar
TEKNIQ is an unknown quantity at this point
Yah, 50lbsft seems a bit much......33lbsft is correct......
7thgensurvivor
38
08-29-2015 11:50 AM
cmart1209
05-29-2015 04:52 AM
PimpBot5000
11-26-2001 07:15 PM
JeffSpeed21
Bolt-on Engine Performance
11-04-2001 12:33 PM
Quick Reply: Torque of front and rear shock tower nuts after new springs
