symptoms of bad strut mounts??
Old Mar 20, 2015
joancasti's Avatar
joancasti is an unknown quantity at this point
my current setup -
GC sleeves with tokico dspec struts.
My front end bottoms out really hard when i hit a small to medium bump. My dspecs are not blown i already pulled them out and checked. My upper front strut mounts are damaged. The rubber where the bearings are completed shredded and ripped on both mounts. Will this cause my front end to bottom out? knock when i hit bumps in the road? cause my front end to hop sometimes? Just looking to clear certain things up. im in the process of getting these fixed this weekend anyways. I just need some input.
Thanks.
Old Mar 20, 2015
GolNat's Avatar
Prelude Owner
Re: symptoms of bad strut mounts??
A knock sound when hitting bumps can indicate a bad strut mount but it bottoming out sounds like another issue.
Old Mar 20, 2015
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Do you have the OEM springs or is this a lowered after market setup? Struts leaking ? What you really need is the OEM springs and struts back. Then you would have a good system.
Old Mar 20, 2015
06 EX Mild Mods's Avatar
06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about
If the rubber is worn out this will cause noise and probably damage, this rubber needs to be replaced or upgrade to poly urethane if available.
Old Mar 24, 2015
emich's Avatar
emich is an unknown quantity at this point
knocking sound could indicate bad ball joints. I found today this is the reason in mine 2001 EX both sides. Duralast **** lasted less than 2 years.
Old Mar 25, 2015
aircooledjames's Avatar
aircooledjames is an unknown quantity at this point
Originally Posted by joancasti
my current setup -
Thanks.
Do you know how to check for blown shocks? Blown shocks can appear completely normal by the eye, even if leakage isn't showing. That's why you don't use GC, you gotta pay to play.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Matteo
Oct 25, 2015 05:46 AM
reqy
Jun 1, 2015 07:05 AM
GH04si
Apr 15, 2015 08:13 PM
bluecoupe
Dec 19, 2001 10:08 PM
