Poly bushings vs rubber
Old Sep 18, 2014
Najitsu's Avatar
Najitsu is an unknown quantity at this point
The dealership said my front bushings were worn so i figured i can replace them with Energy suspensions polyurethane bushings which the shop quoted me at 350 for having them inserted into the LCA, this price includes alignment. It will only be a 40 dollar difference if i was to return these LCA poly bushings and buy new Lower control arms that come with rubber bushings already installed.
I understand that it will make my handling on the car a little more responsive, but that it will also make a squeaky noise in the cold. I will be using this car as my daily driver and don't really plan on increasing the horse power of this vehicle much.
Side note- I put some new loud speakers in my car and plan on sound deadening the vehicle to increase the sound quality. So the rubber may be a better idea and where I live it gets pretty cold and the winters are long.
So my main question is will the poly bushings be worth the extra 40 dollars? How big of a difference is it compared to new rubber bushings? I'm a spirited driver and do enjoy accelerating fast and taking corners hard.
Old Sep 18, 2014
Poopies's Avatar
Super Moderator
Re: Poly bushings vs rubber
I've heard that they make a pretty big difference, especially if you replace all the bushings. I don't have first-hand experience though.
Old Nov 16, 2014
Matteo's Avatar
Matteo will become famous soon enough
any news?? how many miles you got? jw if i need to replace mine too.
i just asked a shop recently about this for front control arm poly bushings and he says yes they will squeak and not recommend it. think he said poly bushings are most helpful at high speeds. BUT he recommends poly bushings 4 front OEM sway bar!.. with no squeaking i guess. i just replaced my engine motor mounts aftermarket OE with a type of rubber bushings and i noticed a positive diff. so im sure replacement rubber front control arm bushings should still help, i think its more an issue of do you want to pay 40 more to drive with squeaking on dailydriver. for me id avoid the squeaking and get rubber...theres many suspension tweaks to do on our cars besides poly bushings
Old Nov 16, 2014
lowlife9's Avatar
they also make these now http://www.moogproblemsolver.com/548...asy-to-install
Old Nov 17, 2014
Matteo's Avatar
^woah nice, i guess according to the pics on their website this is the right one to purchase for the civic: http://www.fme-cat.com/overlays/part...A%20CIVIC&vin= and gets as cheap as in the $20's sold individually.
Old Nov 18, 2014
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
Do you need an alignment after replacing the lower control arm?
I think I'd just go with rubber because the squeaking would annoy me.
Old Dec 15, 2014
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
If you leave the strut to spindle bolts alone, theoretically everything should stay in the same place. The bushings mentioned above would definitely be my choice. I have poly and after I drilled the arms etc to get grease into them and put some wear on them they don't squeak. The design of the "pancake" bushing means the rubber ones wear out quickly. This is the reason I have poly bushings. With all that said the big bushing on the front is the only one to fool with. Unless there is a problem with the rear one leave it alone. It is a major PITA and the pivoting forces aren't the "wrong" direction to it. (This isn't the only vehicle that has "pancake" bushings and they all wear them prematurely.)
Old Dec 28, 2014
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Can you elaborate on what you did there? Where did you put a hole in the arm, etc? I have some energy suspension ones I need to put in but then I read that they would need some grease applied over the years and was wondering how to do that.
Old Dec 29, 2014
Look for zerk fittings
Old Dec 30, 2014
drhawkinz's Avatar
oh gotcha, seems easy enough to put one in. is just one good enough for that big of a bushing or did you put one on each side?
Old Dec 31, 2014
i would guess the answer would be start with one, if it squeaks, install another?
ThatGuy913
Sep 28, 2015 05:35 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
czarlun
Sep 14, 2015 08:16 PM
