tie rod -______-
Old Dec 4, 2012
paulymcd7's Avatar
paulymcd7 is an unknown quantity at this point
tie rod -______-
okay i haven't been on in months but i needed new inner and out tie rods, they were installed and brought to an alignment place and they said the tie rod appeared to be too long because there was no thread showing. Do i need shorter tie rods? I'm about 2 and a half inches lowered I'd say my alignment is toed in by i think 2 degrees on the passenger side, drivers side is fine and perfectly aligned. Did i just get the wrong tie rod or am i lowered enough that i already need shorter tie rods. Basically I'm asking is everyone on here on stock length tie rods?
Old Dec 4, 2012
lowlife9's Avatar
Re: tie rod -______-
what brand ???
Old Dec 4, 2012
paulymcd7's Avatar
skunk 2 and the tie rod is oem or oe my dads an auto parts sales guy for a big company based out of philly so he got it through them so i'm pretty sure its oem anyway do i have the wrong tie rod on or do i indeed need shorter tie rods?
Old Dec 5, 2012
paulymcd7's Avatar
bump
Old Dec 6, 2012
paulymcd7's Avatar
please someone help i have a 8 hour total drive this weekend and a 7 hour drive in 2 weeks and another 7 hour drive in like 5 or 6 weeks i want to get this figured out im wasting tread and i dont want to have to pay for new tires do i need to buy an after market shorter tie rod?
Old Dec 6, 2012
subworm07's Avatar
subworm07 is an unknown quantity at this point
I am lowered below 3 inches and I am on stock tie rods
Old Dec 27, 2012
TFMEX's Avatar
CO&CA
TFMEX is a jewel in the roughTFMEX is a jewel in the roughTFMEX is a jewel in the rough
I too was lowered on Skunk 2 and maxed out about 3" and was on stock tie rods.... sounds like your mechanic doesn't know what hes doing.....
Old Dec 27, 2012
sl33pyriceboi's Avatar
i am lowered 3+ inches and i too am on stock tie rod.
Old Dec 29, 2012
Dean Sanchez's Avatar
Dean Sanchez is an unknown quantity at this point
If your mechanic is saying that the tie rods are too long, just open your hood, take a flash light and look toward the back left/right of the engine where the tie rod meets the tie rod end. If you see that the tie rod end is screwed all the way on the tie rod then you need shorter tie rods. If you see the tie rod end is not all the way screwed on your tie rod, then your mechanic is BSing you.
If the tie rod is too long, just take your car or tie rod(s) to a machine shop and tell them to cut your tie rod(s) a 1/2 inch or whatever length you need to adjust the toe to 0. It should not be too much money for them to cut and re-weld. I have done this already.
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Joecrowe
Sep 24, 2015 09:12 AM
Dangerousjordan
Jul 28, 2015 08:24 AM
17
Jul 23, 2015 11:48 PM
