Need Front Suspension HELP! Cant Drive!!
Old Oct 17, 2012
SSMCivicCoupe's Avatar
SSMCivicCoupe will become famous soon enough
So i just installed my front coilovers and everything went good except for one major thing, my front 2 wheels move in and out and dont stay straight. Also when i was reversing my car down my driveway and i barely turn left it turns the full wheel automatically, same with turning right. I need help asap because i cant even drive. I still need to do my rear. I checked my lug nuts and they are tight. One thing i also noticed is the coilovers are tilted outwards. Please help ASAP!!!
Old Oct 17, 2012
sl33pyriceboi's Avatar
Re: Need Front Suspension HELP! Cant Drive!!
What dp you mean they move in and out?
Take some pis or a vid or something so we can see your install job
....and you got rokkors didn't you?
Old Oct 17, 2012
Im posting up some now. My tire like moves in and out. and when im reversing it wont move at all. it moves very slowly.
Old Oct 17, 2012
Did you connecting the steering rods (tie rod) back to the strut properly ?
Old Oct 17, 2012
Passenger side
File Type: jpg
Old Oct 17, 2012
Driver side
Old Oct 17, 2012
One thing I also noticed is that with the wheels off and the steering wheel perfectly straight that one side is perfectly straight and the other side is turned out words more and when i ever i try to push that side in the other side moves outward and that side becomes straight.
Old Oct 18, 2012
lowlife9's Avatar
you need an alignment and toe adjustment.
Old Oct 18, 2012
So it would be ok to drive on? Would anything like my axles mess up? Firestone is like 5 or 6 miles from my house.
Old Oct 18, 2012
Aetoc's Avatar
Aetoc will become famous soon enoughAetoc will become famous soon enough
It looks to me that your tie rod end castle nuts aren't tightened down properly at all...are they good and tight? I'm not sure of torque spec but it should be fairly snug. I had a similar issue as you, only less severe, that turned out to be one of my tie rod ends not being properly tightened. Once those are good and tight, get an alignment.
Old Oct 18, 2012
Olsen's Avatar
Olsen is an unknown quantity at this point
I just replaced the entire suspension on my 01.
Couple of tips: make sure that the tie rods (and ends) are secured properly (proper torque I believe is 60ft/lbs) and make sure the cv axle and ball joint both are looking good (it's a good time to replace them if they look like they've torn at all). Also make sure the strut mounts (and struts) are facing the correct way (there should be lines that mark the correct direction, but if there isn't you'll have to line them up yourself by determining the correct angle that matches the metal cover under the hood). I know I had a similar issue and when I'd turn I'd hear popping noises and even screetching noises at times and couldn't think of what could be the issue until I replaced the mounts and now everything is perfect! Don't do the alignment until after you're done messing with the suspension though cuz if you get it done and go back in, you'll only need another.
Old Oct 18, 2012
Max91's Avatar
Max91 is an unknown quantity at this point
I've been following your quest SSM. I hope you get it figured out, I'm ready to do the same thing.
I agree with olsen. The might try retracing your steps to at least get the wheels even before an alignment instead of having to pay twice, or the mechanic finds something that cost more money. (especially at Firestone).
Keep us posted!
Old Oct 19, 2012
Problem solved. It just needed an allignment.
Old Oct 19, 2012
enigmatic jc's Avatar
enigmatic jc is an unknown quantity at this point
nice...post pics of the ride!!
Xuhme
21
Aug 7, 2023 03:40 PM
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
smmahan
Apr 15, 2015 08:17 PM
GH04si
Apr 15, 2015 08:13 PM
