Suspension Help
Old Jun 6, 2012
aschattke's Avatar
aschattke is an unknown quantity at this point
Suspension Help
When I bought the car it had ground control coilovers on it. 50k miles later the ride has just gotten unbearable and one of them just started rattling. I am not very knowledgeable when it comes to suspensions. I need to know what parts to buy, struts and springs??? This car is my dd and I dont need a performance suspension on it. I need the lowest cost solution that is going to provide a decent suspension.
When I bought the car the owner threw in a set of new springs he had laying around for the car. The box they were in say they are for an 01-03 celica. Can I use these springs?
Old Jun 6, 2012
Aetoc's Avatar
Aetoc will become famous soon enoughAetoc will become famous soon enough
Re: Suspension Help
Well if the springs are for a civic, then yes...but the box doesn't help with knowing that...Your best bet is to buy a new or used set of front and rear strut assemblies...then you can just unbolt the old, and bolt up the new. Odds are the stock struts are blown from the GC's so its not work reusing the ones you have. That and it will be extremely difficult to remove the old GC sleeves, unless they are relatively new.
Old Jun 6, 2012
aschattke's Avatar
Re: Suspension Help
Is there a way to tell if these springs are for a civic? Any suggestions on a cheap place to get the struts from? You think I should just go OEM?
Old Jun 6, 2012
lowlife9's Avatar
Re: Suspension Help
if you use oem struts with the ground control springs you have now your going to be rite back were you started in a couple months when they blow. if you get oem struts your going to need oem springs. or you can use the ground control springs you have now and just upgrade your struts to something that can handle the ground controls like Koni yellow.
Tedverseti
Apr 23, 2020 01:45 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
