Help on installing driver side steering stablizer link
Old Dec 16, 2011
hqfking's Avatar
hqfking is an unknown quantity at this point
Hi guys,
This is my first posting at here.
When I had my front two tires changed today, I just found that the drive side steering stabilizer link is broken. So i just ordered a new one online, any help on how to install it by myself will be appreciated. Thanks.
And the car also got two CEL code: p0420 and p1457. Any suggestions.
The car is 2003 honda civic Ex couple, 60000mile. I found online that the CAT is under some warranty, but I don't know whether mine still under it or not? Is there any number I can call?
Thank you all.
Old Mar 8, 2012
scooty's Avatar
scooty is on a distinguished road
Re: Help on installing driver side steering stablizer link
You'll need an allen key (5mm i think) and a wrench (13mm ?). The allen key is to keep the threads from spinning when you undo the nut using the wrench.
Two things:
1) Spray the bolts and nut with PB blaster. Not wd-40, PB Blaster or equivalent. Let it sit for a few minutes.
2) Use the correct size and good quality allen key, make sure its a metric size. Do not use one that's all worn out on the ends. Buy one if you have to, don't cheap out.
Ignore these steps and you will end up with a stripped bolt and a big headache. While you're at it, do the other side as well, its probably gone too.
Old Mar 8, 2012
sl33pyriceboi's Avatar
oh jeeeze
Old Mar 8, 2012
04 Honda Civic's Avatar
Do what scooty said.
Use a GOOD allen key. LOTS of pb blaster. Maybe even heat.
P0420-Catalyst system efficiency below threshold. Possibly from a bad cat. Have you driven with a check engine light for a long time?
P1457-Thats an evap code I think. Do you fill your car with it running? Do you make sure you tighten it three clicks? If not you could have a bad gas cap or something else. I would clear it and see if it comes back.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ashlava71
May 16, 2015 12:54 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
ej8
Apr 13, 2015 06:36 PM
mwwhonda
Nov 7, 2001 07:24 PM
