sway bar issue
Old Oct 12, 2011
jered123's Avatar
jered123 is an unknown quantity at this point
sway bar issue
i put a 22mm tanabe sway bar with a tanabe concept g exhaust on my ep3 and the exhaust rubs on the sway bar...does anyone know of a fix that doesnt involve bending my exhaust pipe or sway bar?
thanks
Old Oct 12, 2011
maxtierney's Avatar
EM2ti
Re: sway bar issue
If you have the clearance (between your tip and the rear bumper), you can modify/bend your hangars and/or swap the hangar rubber pieces to pull it in a bit (if they are worn/droopy). Not too common to have clearance issues with a 22mm swaybar.
Old Oct 14, 2011
jered123's Avatar
Re: sway bar issue
yea both of those are ideas ive had..i was just gonna take it to muffler shop and let them figure out a way to fix it cuz im too lazy to take it all apart..thanks for the reply
Old Oct 15, 2011
Re: sway bar issue
i simply did change the rubbers and added a rubber on the sway bar using common brackets.
Old Oct 16, 2011
jered123's Avatar
Re: sway bar issue
i took it to a muffler shop and they bent the hangers a little so its good now
mrohitredd
Jun 9, 2015 06:37 AM
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
Jodster
Dec 15, 2001 07:49 PM
