Control arm help Please!! i need help asap
Old May 29, 2011
arubio0812's Avatar
arubio0812 is an unknown quantity at this point
alright so i was changing my control arm on the passenger side of my 2002 ex 4dr and well i disconnected the sway bar control link, and the two big bolts that connect the arm to the frame. BUT! the ball joint part is stuck. I took off the crown bolt but its stuck. Ive tried hitting it with a hammer, prying it with a crow bar. Im out of ideas and im going to get a puller from storage tomorrow morning but i need to be at work at 10am tomorrow so any tips or tricks i would really appreciate!!! THANKS!!
Old May 29, 2011
MindBomber's Avatar
Live for the Twisties
Re: Control arm help Please!! i need help asap
Have you already attempted putting a rachet in between the lca and knuckle, then letting lowering the car back on the ground?
Old May 29, 2011
^yup, pretty famous in the utube.
Old May 29, 2011
lazlong's Avatar
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=136&t ransactionid=1306723794-7190173246&posted_by=lazlong_www.civicforums.com&y outube_video_id=ISY8bGof3bQ[/autostream]
Old May 29, 2011
arubio0812's Avatar
that is the most beautiful thing i have ever seen ever... thanks guys i appreciate it!!
Old May 29, 2011
BlueEM2's Avatar
Whachya lookin at?
Hahahaha glad it worked... you shouldaa used my ball joint DIY as a start... It will get you through a lot of the LCA job Linky in my sig.
Old Jun 9, 2011
CGaud's Avatar
CGaud is an unknown quantity at this point
Speaking of lca's... My bushings are cracking pretty bad in front and I'm looking to replace them. Dealer wants $350 to replace and press in new bushings. I want to do the job myself but was curious on my options for replacement parts. Do I 1) replace with OEM bushings 2)replace with an aftermarket (performance) bushings 3) replace the entire front lca with a better one (not sure if there is even an aftermarket front lca).
Old Jun 9, 2011
lowlife9's Avatar
Dezod has ingalls lca's for 89 dollars each they come with polyurethane bushings. http://www.dezod.com/cat_control_arms.cfm
Old Jun 10, 2011
CGaud's Avatar
Put a giant FAIL on my forehead! Thanks for the input LL... you are my savior
Old Jun 10, 2011
CGaud's Avatar
While I'm down there... Are there any other bushings I should replace while I'm at it? My ride isn't currently dropped but I'm planning to do it in the near future.
Old Jul 19, 2011
CGaud's Avatar
So I ended up buying the front lca & purchased the energy suspension front control arm bushing kit. I think I duplicated my purchases... does anyone know for sure?
GolNat
Jan 12, 2021 09:06 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
muttleytm
Jul 14, 2015 05:31 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
fordover
Jul 11, 2015 09:10 PM
