My tokico dspecs came in today!
Old Nov 17, 2010
MarkieMark's Avatar
MarkieMark will become famous soon enough
My shocks just came in today woohoo!
I finally ordered them lol..
I got 01-02 dspecs.. I'm kind of scared of the drilling part.
I have a few questions:
-Is there anything else I should look out for besides the drilling of the holes to 16mm?
-Also is drilling my best bet? I did some searching and found out that some use "spacer washers"
-This might be a stupid question but do I need a spring compressor when installing gc sleeves onto tokico dspec shocks?
-Also can that silver collar/ring on top of the front shocks come off?
Get back at me. Thanks!
Old Nov 18, 2010
jbrown59's Avatar
CIVIC USER
jbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trusted
Re: My tokico dspecs came in today!
Im assuming you drive the 03-05 or above em2 so yes, drilling will be the only way to get these on your car.
With GC sleeves u will not need a spring compressor and yes that silver collar does come off...just use a flat tipped screw driver and a hammer to knock it off and then put everything back together.
Let me know how the ride is, DSpecs are adjustable right?
I had tokico blues and gc sleeves for a year and then changed to tein ss because the ride was to rough for me, hopefully this set up will work for you. The thing I loved most about my first set up was cost and ease of installation and adjustment, very nice look!
Old Nov 18, 2010
MindBomber's Avatar
Live for the Twisties
You'll need a spring compressor to disassemble your current struts, unless your planning on purchasing all new mounts, bearings and dust boots.
If your nervous about drilling the holes, why not let a shop do that part for you?
Old Nov 18, 2010
MarkieMark's Avatar
Thanks!
Yeah, the dspecs are adjustables. I was gonna go with the blues but changed my mind last minute lol. I got the dspecs for 539 shipped @THMotorosports. Fast shipping but I'm missing one nut and 3 protection caps. What is that silver collar for? Is it just some cap?
Old Nov 18, 2010
lordhelmet's Avatar
You don't need a spring compressor to disassemble the stock struts. Take the strut out into the driveway and unscrew the nut. I've done this on my car twice and the farthest any piece has flown is about a foot. The compressors are only helpful in installing the spring back onto another strut.
Old Nov 18, 2010
MindBomber's Avatar
I've done it a few times as well, and your probably safe taking it apart our struts without a spring compressor. It's safer to use a compressor and a good habit to be in though, so since they rent them for free at most auto parts stores, you should use a compressor.
I should take my own advice.
Old Nov 18, 2010
sam68's Avatar
sam68 is an unknown quantity at this point
Just did mine without a spring compressor also put new lowering springs on my D-Specs without a spring compressor with no problems.
Old Nov 18, 2010
lordhelmet's Avatar
I've gotten either the stock front or back springs(don't remember which) on new struts without a compressor. I had to rent the spring compressor half way through the job. I was angry.
Old Nov 18, 2010
MindBomber's Avatar
I managed to replace the front and rear struts without a spring compressor, it would have taken half the time had I rented the free spring compressor though. I ended up using the OEM jack to compress the strut enough to get it in place..
Old Nov 19, 2010
roadkill in the making
I used compressors, so not sure.
Old Nov 20, 2010
MarkieMark's Avatar
can anyone else confirm that it is safe to take off the silver collar/cap on top of the front shocks?
Old Nov 20, 2010
lordhelmet's Avatar
Why would you want to take it off? I recall my blues having the collar. I left it on.
Old Nov 20, 2010
MarkieMark's Avatar
so that my gc sleeves can slide in? or would it go on no problem?
Old Nov 20, 2010
lordhelmet's Avatar
Wait, do you have the GC sleeves? Try sliding it on. If it slides on then it slides on. If not, it looks like you are forced to take the caps off.
Old Nov 21, 2010
MarkieMark's Avatar
okay i'll try it when it comes to installing. the gc are on my stock shocks right now. i'm waiting for the missing nuts the distributor forgot to send me.
Sep 27, 2015 11:33 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
Dave Brabant
Sep 10, 2015 06:48 PM
Bricoleur
Sep 9, 2015 06:48 PM
MamaBear2015
Sep 7, 2015 06:00 PM
