STILL a rough ride. HELP!!!
Old Mar 23, 2010
rhymeboy89's Avatar
rhymeboy89 is an unknown quantity at this point
Hi everybody,
this is my first post on this site but read a lot from it. To begin my problem I feel like my ride is really rough over certain bumps.
The things i have done to counteract this are:
Tokico HP blues (all around)
new lower control arms (both front)
new ball joints and tie rods (both front)
all ready had eibach springs (not sure if it is 1.5 or 2) for the most effective answers please answer for a 2" drop
Things that I think could cause this:
No front bump stops
Eibach springs getting old? (thought springs last a lifetime)
Tokico blues cant handle 2" drop
No camber kit
running Nankang NS-1 215(or 225 i forget)/45/R17.
Roads in Long Island and Queens are just plain crap?
Additional info that i feel might be important:
After I installed the lower control arms (did each side seperately do to money issues) the ride was where i wanted it to be but would go back to rough maybe 3 weeks later.
Any ideas? Am I missing something obvious? I might be putting on General UHP's today but idk yet cause I don't know how much the tires could be effecting it.
Old Mar 23, 2010
lowlife9's Avatar
Re: STILL a rough ride. HELP!!!
alot has to do with tire size 17s are a rough ride. how long have the blues been on a 2 inch drop ??? blues are valved differentially then stock so they wont be as comfortable and thats not saying much because stock is not the most comfortable ride either. you cant expect the most comfortable ride with your setup.
Old Mar 23, 2010
mitsusqueeshee's Avatar
mitsusqueeshee is an unknown quantity at this point
I run Neuspeed lowering springs, with 18's and when I bought the car, it rode terrible. The shocks were all blown out. I have since installed KYB AGX adjustable all around and the ride is much improved. I do run it at the second to hardest setting though. Your TOKICO blues may not be able to dampen those Eibach springs sufficiently so you might consider going to an adjustable shock like AGX, or KONI etc. Its NEVER going to ride a comfortable as stock!!! The car handles very well now btw.
Old Mar 23, 2010
rhymeboy89's Avatar
**** was hoping with enough things changed I could make it ride like a g35. Guess I'm gunna cancel buying those tires then. Thx for the info tho. Guess its time to save for a new car love this car but hate when i hit a bump my car feels like it got punched.
This concludes a k20 project before it even begun lol.
Old Mar 23, 2010
information's Avatar
information should not be trusted
u can blow brand new shocks in 10 miles without bump stops . when a shock bottoms out without a bumpstop its ruined .
Old Mar 24, 2010
also recommend finding bumpstops designed for lowered cars, if they exist...
Old Mar 24, 2010
lowlife9's Avatar
just cut the bump stops in half.
Old Mar 24, 2010
to myself -> 37 y old age is not good for my memory.
Old Mar 25, 2010
lowlife9's Avatar
some eibach applications requires trimming your bump stops look it up yourself . but removing them completely is just stupid.
Old Mar 25, 2010
don't worry, the emoticons are for myself, not for you.
Yeah, i forgot i was in the civic forum, i have a miata too and they have a lot more aftermarket bumpstops, that was the reason i said different ones. civics are more on the trimming the stops, so ouch to me! i am the one getting beat here!
Old Mar 26, 2010
rhymeboy89's Avatar
well thats the thing i didn't know i didnt have bumpstops. They put on the shocks and never mentioned that to me until i asked them if i had bumpstops. On that note I'm gunna go check if my shocks are blown out. If they are im gunna be ****in pissed because they never mentioned **** to me. If they arent then idk.
Will getting bump stops stop this loud thud i hear when going over slightly bigger bumps? Thought it just stops your car from bottoming out unless i always bottom out and just didn't know it.
Old Mar 26, 2010
lowlife9's Avatar
it stops the damper from being damaged in the event of bottoming out they should have reused the stock bump stops and modified them.
Old Mar 26, 2010
shocks vs bumpstop rubber (or soft compound) - will happen, but what give and deform is the stops.
Shocks vs whatever is above (not soft, does not compress) - what give and deforms (a bit, before blowing) is the shock...
Hutch1051
Sep 29, 2015 09:20 AM
speedlever
Sep 24, 2015 07:18 PM
RSKtakR
25
Sep 14, 2015 07:43 PM
2.0.0.2
Sep 14, 2015 06:38 PM
Mannimarco
Sep 7, 2015 10:01 PM
