Tokico D specs good?
Old Dec 11, 2009
Infernocvc's Avatar
Infernocvc is an unknown quantity at this point
Exclamation Tokico D specs good?
Hi guys. I'm new here and I have an 05 Honda civic sedan DX-VP dropped on Tenzo-R springs, and there dropped about 2" on front and rear with stock shocks. Horrible I know. I was wondering what shocks to go with? I was thinking of getting Tokico D-Spec Adjustable Gas Shock Strut, I've also searched a bit i read they handle a 1.8" drop on the front and 2" drop on the rear, other then that I can't find any other shocks. Also I noticed the website says its fits for 01-02 Civic Sedans, will they fit for an 05?
Old Dec 11, 2009
Re: Tokico D specs good?
01-02 and 03-05 have slightly different suspension designs, i believe the bolts would not line up properly. the d-specs are nice cause they are adjustable, im not sure if they work for that low of a drop. the blues are for max 1.7 inch i think, those could work too but they might not last as long as they would normally. make sure its the right part for your year.
Old Dec 11, 2009
civic04coupe's Avatar
civic04coupe is an unknown quantity at this point
the d-specs are excellent!! i highly recommend you getting those!
Old Dec 11, 2009
MidnightCivic's Avatar
There you go, great price jump on it
http://cgi.ebay.com/ebaymotors/xx-TO...Q5fAccessories
Old Dec 11, 2009
kc8ktq's Avatar
kc8ktq can only hope to improve
For 03-05 civics you need to use the Tokico HTS series. They are the same thing as the D-specs. The part number is HTS-508. That includes all 4 corners.
Old Dec 12, 2009
Infernocvc's Avatar
Thanks! Would it handle such a low drop though?Ive found some HTS I can pick up but im just worried about blowing brand new shocks..
Old Jan 12, 2010
mp3runner1's Avatar
mp3runner1 is an unknown quantity at this point
Very good specs dude. You will see a huge difference
Old Jan 10, 2011
blazed870's Avatar
blazed870 is on a distinguished road
How low of a drop can you go with the D-Specs without worrying about damaging them? I have 1.75" Gold Line drop springs with Tokico Blues right now, but it is time to replace.
Old Jan 10, 2011
sl33pyriceboi's Avatar
Dspecs are built well. u can go well beyond 2"
Old Jan 10, 2011
blazed870's Avatar
Thanks sl33priceboi. If you could get the D spec or Koni's, which would you go with? I am looking for the best ride as a DD not for racing or aggressive driving.
Old Jan 10, 2011
i currently have konis. when i was ready to buy suspension, i did my research and it did boil down two the two (koni or dspec)
from what ive read/researched koni offers superior dampening, they are rebuildable (but both are high quality and will last you more than 100k miles).
however, koni yellows are a PAIN IN THE @SS to install. u gotta cut ur OEM strut and insert the tube. (search and you'll see wt i mean). let me repeat, they are a PITA to install.
however, once installed, they are awesome. full stiff is stiff. handling is awesome. full soft is not too soft and the ride quality is excellent. its my DD.
however, if i had to do it again, i would get the Dspec just for the sake of easy installation (direct replacement strut). although the dampening adjustment is not infinite like the koni's (which is worthless imo), the Dspec can still adjust from full firm to full soft (i think its like 15 or 30 clicks or something)
u cant go wrong with either one. id advise you to get Dspec.
Old Jan 13, 2011
blazed870's Avatar
I followed your advice sl33pyriceboi and got the D-Specs for $550. Thinking about doing my bushings while I am at it.
Old Jan 13, 2011
do it. lowering puts a LOT of strain on ur LCA bushings (lower control arm).
get energy suspension LCA bushings they are great.
Old Feb 27, 2011
mando_vzl's Avatar
mando_vzl is an unknown quantity at this point
Just be advised that once you put polyurethane bushings in your suspension set up, the ride WILL be much firmer than stock as they are a "sport" upgrade not meant for touring.
Check out the Suspension FAQs: https://www.civicforums.com/forums/f...aq_susp_faq_q1
my 2 cents.
Old Feb 28, 2011
i have the ES lca bushings and they do not affect ride quality at all. except in the winter you can hear them squeak going up driveways or over potholes. well worth having them to keep the alignment tight and better cornering. the first day i drove with em i couldnt even tell a difference til i took a hi speed curve and it grabbed much better. otherwise i doubt you would even notice. its one of those mods you do just so it lasts forever and you dont need to keep changing the oem rubber every few yrs. the only suspension upgrade ive done that made the ride firmer is lowering springs and shocks. the ES motor mount added a tiny vibration but now its hardly noticable if at all.
Old Apr 30, 2011
bigheadmark's Avatar
bigheadmark is an unknown quantity at this point
I have been doing a bit of searching, and found a couple websites that were listed as sellers of tokico blues struts...ebay, and dezod...are there any other websites that sell these that anyone can think of
Old Apr 30, 2011
goggle...
procivic, thmotorssports, etc
http://www.google.ca/#hl=en&source=h...91afe43845c36f
Old Apr 30, 2011
thanks sdaidoji !! I like the prices of the Tokico hp's at THMOTORSPORTS
reqy
Jun 1, 2015 07:05 AM
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
