major problem please help me
Old Jul 27, 2009
khwin's Avatar
khwin is an unknown quantity at this point
so i was starting the process of lowering my car today, i took the rear divers side wheel off took off the 2 bolts in back and lubed up the screw that connects the bottom of the strut to the lower control arm, i kept greasing it for about 30-40 mins and then started to use a torque wrench on it, it nudged a bit and i kept going, next thing i know the damn head broke off of the screw! i drilled a hole in the broken screw and then attemped to use a screw extractor after another hour of lubing the screw and that broke off in there too, what the **** am i supposed to do now, please help
Old Jul 27, 2009
Re: major problem please help me
you may need to drill it out completely to get the parts taken off. then tap new threads and use a different screw. or replace with new parts. same happened to me but i had a shop do it and they said they were able to drill the whole thing out and just use a bigger screw.
Old Jul 29, 2009
TheItalian's Avatar
TheItalian is an unknown quantity at this point
Smile Re: major problem please help me
GearBox has got the best answer your gonna get for that question..happened once with me also..had a shop take it out and fix it..same as he did...
The Italian
Jon-Ohio
Jun 30, 2018 08:10 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
lapchern
Bolt-on Engine Performance
Dec 22, 2001 06:23 PM
