01 civic ex coupe struts
Old Feb 21, 2009
odm4286's Avatar
odm4286 is an unknown quantity at this point
What struts do I need to replace my front struts on this car. Im looking for something that will give me a bit of performance over stock. I will be using my stock springs as well not ready to lower the car yet
PS: as you can see above I tried koni sports but they didnt fit my car saddly and would have required me to cut the stock shock. So if you guys could PLEASE help me find some struts with the bottom mount already assembled
Old Feb 22, 2009
DDragon7's Avatar
Re: 01 civic ex coupe struts
Koni, is one of the best that you can get, but it does require you to cut the stock shocks. If your just looking for an OEM replacement, but performs better, I recommend Tokico HP blue.
But if you already got the Koni yellows, I recommend you put those in.
Old Feb 22, 2009
Pachanga02's Avatar
Pachanga02 is an unknown quantity at this point
i would definitely put the koni's in, why buy others when you have good ones already.
Old Feb 23, 2009
odm4286's Avatar
I really dont feel too confertable cutting my stock struts is there any high performance strut I can buy for my car that comes as a full assembly?
Old Feb 23, 2009
DDragon7's Avatar
I think they were call Tokico D-spec, those are pretty good shocks, and they are adjustable.
Did you read the DIY on installing those Konis? A lot of people would rather put in the Konis.
Old Feb 23, 2009
roll_outz's Avatar
roll_outz is an unknown quantity at this point
Y don't you use your koni since you changing ur strut.instead of trowing them, cut them and used it w/ your koni..
Old Feb 24, 2009
odm4286's Avatar
well ive already sent the konis back how are kyb agx adjustables I talked to the rep at tirerack.com and he told me they come as a full assembly
ghondavic
Transmission
Apr 12, 2017 09:37 PM
Civicman92296
Apr 23, 2015 09:22 PM
coupeciv
Exterior
Apr 23, 2015 06:48 AM
lilbluecivic
Nov 7, 2001 06:49 PM
ZSKCivic01
Nov 4, 2001 08:47 PM
