Need info on strut bars, frame brace etc.
Old Dec 23, 2008
Maple50175's Avatar
Maple50175 is an unknown quantity at this point
Does RSX bars fit in an em2 02 civic coupe?
What fits? and what doesn't I really want to get a front strut bar as well as rear.
Also, How do those under engine body frame things I see on ebay work. Worth it? Let me know!
Old Dec 23, 2008
robbclark1's Avatar
Retired suspension supermod.
Re: Need info on strut bars, frame brace etc.
None of them are worth it. Save your money for better parts.
Old Dec 23, 2008
Zzyzx's Avatar
Autocross Junky
are you chasing down that last 10th of a second?
If not... then all chassis bracing is going to do is influence the "feel" of the car, which may exactly what you are looking for.
Old Dec 29, 2008
Know what? It really feels different. Neuspeed one just in, moved the clutch reservoir and the hydros of steering to clear space.
It kind of have a more "strange" feeling, the roll seems kind of odd during a quick 3 mile drive to check for loosen stuff. No noise so far, but a quick push in a corner indicates an increased understeering, but more controllable (it was already way more controllable than the Miata I have, BTW).
Soon I have more seat time, i might post the findings. the odd feeling might go away when i soften the dampers (currently 3 of 4 in the AGX KYB).
Interesting.
Old Dec 30, 2008
robbclark1's Avatar
Interesting.
again, we know it "feels" different, but take two laps without it and two laps with it and tell us which times are better. The results will probably be that either your laps are the same or that they got worse with the strut bar.
Old Dec 31, 2008
Ahhh, March is sooo far away... sniff. winter takes too long, without the weekend autoXees. If i can take it out during the lunch time, i will try that
Old Jan 21, 2009
dscottb01's Avatar
From: Scott County, KY. Where else? This is my town! Na na na..na..na..
dscottb01 is an unknown quantity at this point
I have found that there are not a ton of options on suspension bracing. I am looking for particular things if anyone has some ideas.
Front Strut Tower Brace
Upper Rear Strut Brace
Lower Rear Tie Bar
Adjustable end links
Moving the car from HS to DSP and Road Race setup.
Old Jan 22, 2009
Zzyzx's Avatar
Autocross Junky
Lower Rear Tie Bar
the upper & lower rear bracing is something you are going to find to be more or less useless. The Shock's are mounted right in to the floor pan (rather then raised Towers like the older civics), and the lower control arms have not run in to the same tearing out problems the old civics use to have. The front upper may have some benefit, but the strut towers are pretty close to the fire wall as is.
I'm not sure what you are asking for with adjustable end links.
Old Feb 12, 2009
didn't know that about the rears... then the best would be the rear sways?
Have a lot of understeers with eibach springs (0.75" lowering that are really more than 1"...) and rear sway in hard.
Progress sways then?
Old Feb 13, 2009
Zzyzx's Avatar
Autocross Junky
I'd be looking to do a couple of things. 1st one would be to optimize the cars alignment. after that i'd reassess the car and see if it needed further tuning.
as far as anti-roll bars, leave the front one stock for now and just tweak the rear.
Old Feb 13, 2009
Well, actually, I have some ingall's front camber bolts, but the shops tell me that they tend to break, best is to slot the struts to allow for camber adjustments, but still wondering about if this is best...
Sways? Front is back to stock a long ago to hold on the front grip, running the AGX 4 at rears and 2 (of 4) fronts. I believe just need more camber in the fronts to hold... Very close to 3 wheeler now if not tight turns.
I can hear you telling me to not to mod without thinking(me on the left!), but i did mod the car to DSP before starting autoX... Not gonna back that now to stock... Sniff. Only way is forward now!
Old Feb 17, 2009
Zzyzx's Avatar
Autocross Junky
I've been running a set of camber bolts for 5+ years now with 4years of competition on them. They don't break unless you grossly over torque them (I've never personally seen one break). Granted they can slip out of adjustment if you don't torque them enough.
Slotting the bolt holes on the strut can work, however it is a one way modification.... as in once the strut is slotted, you cant un-slot it. Another thing to look in to would be camber plates.
Old Feb 21, 2009
Thanks, will try to find a place they can put them in (current nuts are "round"... can't take them out without air tools... 350 tork electric one does nothing...)
me on the left
Old Feb 21, 2009
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
All of the RSX stuff will fit the EM2
Old Mar 1, 2009
Maple50175's Avatar
yea i have the progress rear sway bar and love it
bluecoupe
Dec 20, 2001 07:12 PM
bluecoupe
Dec 19, 2001 10:08 PM
Daniel420
Dec 4, 2001 08:46 PM
bluecoupe
Nov 28, 2001 08:21 PM
CapYoda
Nov 20, 2001 10:36 PM
