struts for 02 civic lx sedan??
Old Nov 11, 2008
bman's Avatar
bman is an unknown quantity at this point
im on a tight budget but i also want to buy decent struts to lower my car. any good brands for a tight budget or any good websites to buy from? thx
Old Nov 11, 2008
robbclark1's Avatar
Retired suspension supermod.
Re: struts for 02 civic lx sedan??
Your answer is in the FAQ.
Old Nov 15, 2008
Deepa's Avatar
Deepa is an unknown quantity at this point
Hey man, the most cost effective struts I found were RSX struts, I picked up a
full RSX A Spec front and rear (strut tops, struts, springs; front/rear) w/about 10k on them for $100. The struts themselves are about an inch shorter (sorry, no measurements) so they will work out pretty nicely. I'm running neuspeed street springs and the ride is much stiffer than stock but still really good considering a 1.75" drop.
My car is an 02 ES1, there was some confusion if they will work at all because there are 50mm vs 55mm housings and the RSX and later Civics use a beefier 16mm lower bolts vs 14mm for 01-02, I just grabbed the RSX Tie Rod Ends ($60ea @ dealer, couldn't find them elsewhere) and everything bolted up perfectly, even the brake hoses.
100+120=$220 which isn't bad at all. A little more if you pay someone to install.
Old Nov 17, 2008
katzenjammer84's Avatar
katzenjammer84 is an unknown quantity at this point
Check the FAQ's.
I'd see if you could locate something used, honestly.
Old Nov 18, 2008
bman's Avatar
i already checked the faq. most of them were coil over and the other guy stated koni yellow or kyb agx (reds) but they're running about 600 bucks for a set. might as well put an extra stack and i can get myself a decent turbo... anyways i decided to keep my old springs and shocks and just cut my springs to lower my car. well at least just for now bc i wana save up for a turbo in the future and then wen i have enough money i'll lower my car the "right" way. i've been searchin every where for used struts but cant find any luck. thanks guys for all your help
Old Nov 18, 2008
robbclark1's Avatar
cutting your springs is stupid and dangerous. Our springs, especially the front ones, SHOULD NOT be cut. I am not saying that cutting all springs is bad, but would you throw a cheap manifold on with a good turbo? No, you do it right the first time. It is stupid IMO to lower your car just because you feel like it rather than having all the right parts.
And yes, your answer is in the FAQ. There is a post on shocks for our cars. If you want to lower, the Dspecs, AGX, and Koni Yellows. End of story.
Old Nov 22, 2008
bman's Avatar
ok so i cant do it with our 7th gen then lol. bc my friend drives an audi a4 and he cut his stock springs he said he wasnt too bad but eventually wen he saved enough money he dropped it the correct way. my other friend also did the same on his 96 civic. also, how low can i lower my car with tokico blues or kyb gr2? sorry that im new to this and still a noob but thanks for all the input BTW I DRIVE MY CAR DAILY IN CITY AND SUBURB SO IM NOT LOOKING FOR RACING SPRINGS OR SHOCKS.
Old Nov 23, 2008
robbclark1's Avatar
Every suspension is different. Cutting springs is the old way to lower a car and it can be very dangerous. Cutting a progressive spring without a dead coil changes the spring rate and leaves it vulnerable to breaking. Your friends are stupid ricers who don't know ****. Cutting certain aftermarket springs can be done, but rarely can OEM springs be cut.
Well you have to decide what type of drop you want. If you want a mild, yet inexpensive drop get the Tokico blues with the eibach prokit. Or you can get the RSX A spec kit (you will need new tie rod ends).
Anything lower than 1" you should get better shocks than the blues. I will reinforce again, either do it right the first time or you will be paying more later down the road. And since you don't have the money, then I suggest you wait. My biggest concern is that you seem to be in a rush to lower your car without thinking through the consequences. What's the rush?
Old Nov 24, 2008
bman's Avatar
you're right man i shouldnt rush into things. i'll wait to save money and do everything the right way thanks
Old Dec 5, 2008
jschuc's Avatar
jschuc is an unknown quantity at this point
I have a 2002 honda civic which I bought lowered. I exported the car to costa rica and it is terrible here with the roads. I am desperatly looking for springs to buy or trade when I go home for Christmas. If there is some way we can work together, send me an email at jschuc1 at hotmail
thanks,
john
Old Jan 11, 2009
Pachanga02's Avatar
Pachanga02 is an unknown quantity at this point
i like kyb i've had them on all my cars. Your better off waiting and lowering it the right way
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
GH04si
Apr 15, 2015 08:13 PM
Rardon6thgenCiv
Apr 15, 2015 07:37 PM
dano2005
Apr 14, 2015 01:58 AM
