Tokico Blue Installation
Old Sep 3, 2008
jgcentury's Avatar
Love me some nice, long-lasting vics!
jgcentury will become famous soon enoughjgcentury will become famous soon enough
Exclamation Tokico Blue Installation
I attempted to search but didn't find the answer I am looking for. I am about to install tokico blues with tanabe df210 springs on my 04 lx, does anyone know if I should replace my strut mounts, dust boots, and bump stops? Do any of these things come with my new struts? (I have not recieved them yet)
If I reuse the original stuff, should I cut my factory bump stops? Thanks to any and all who read this and can provide any knowledge.
Old Sep 3, 2008
bluecivic_19's Avatar
bluecivic_19 is a jewel in the roughbluecivic_19 is a jewel in the roughbluecivic_19 is a jewel in the roughbluecivic_19 is a jewel in the rough
Re: Tokico Blue Installation
dunno
Old Sep 3, 2008
joking, u can use the same strut mounts, dust boots, and im not sure bout bump stops. and i dont see y it wouldnt come with them. im on coilovers so it came with everything i needed cept for the dust boot for the back which i reused
Old Sep 3, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
basically take everything off that looks connected and then reverse order. lol all the stuff is not very hard to locate if you know absolutely anything about suspension.
Old Sep 3, 2008
Oh1CivicRev's Avatar
Oh1CivicRev is an unknown quantity at this point
I installed tokico blues over the weekend. The only thing that came in the box was the shock itself and a new nut for the top of the strut. Other than that, you will need to reuse everything from the old strut. Depending on how much you are lowering your car, you may need to trim your bump stops. I dropped mine on tein s-techs (about 1.5" drop) and did not cut my bump stops. I haven't had any problems yet.
Old Sep 3, 2008
jgcentury's Avatar
thanks my fellow civi brethren!
Old Sep 3, 2008
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
My fronts didn't really have a bump stop, but a trimmed the dust boot a little and the rear had bump stops and I cut them in half, OEM I mean.
Old Sep 3, 2008
dj_cronic_metal's Avatar
dj_cronic_metal will become famous soon enoughdj_cronic_metal will become famous soon enough
shouldn't need to do much when you install. Watch out in the hat though. For some reason there is ball bearings inside.
Old Sep 5, 2008
jgcentury's Avatar
thanks very much all!
Old Sep 12, 2008
03cvic's Avatar
03cvic is an unknown quantity at this point
Hi, could you tell me how do i install the rear struts back on the car? i have 03 civic lx 4dr. I got stuck at putting them back on the car after putting the stock springs back on tokico struts. The end of the struts (where the 17mm bolt go through) is lowered than where it supposed to go to.
http://s277.photobucket.com/albums/k...t=IMG_0154.jpg
Thanks,
Old Sep 12, 2008
lordhelmet's Avatar
have someone step on the drum.
Old Sep 12, 2008
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
did you compress the spring correctly when you put it back together? Is it seated and bolted from the top completely?
Old Sep 12, 2008
You can either step on the drum to help get it in place or use a pry bar like I did. Either way it's a two person operation.
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
CivicsClass101
Jul 9, 2015 11:14 AM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
reqy
Jun 1, 2015 07:05 AM
