Bolt size of bottom strut
Old Jul 2, 2008
Albertross's Avatar
Member
Albertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond repute
The damn nut on the bottom passenger strut that connects to the rotor is a little rounded because the damn thing won't come off. Tried impact wrench, tire iron with all my weight on it (at least 20 tries), WD-40, almost everything. Still nothing, and now the nut is a little rounded from all that stress.
Would I be able to get that 19mm nut from any hardware store? I.e. Home Depot, Rona, Canadian Tire? Or am I looking into having to go to Honda and getting that nut?
Btw, my bad for the error in the title, it's supposed to be nut, not bolt. ^^
Old Jul 2, 2008
sl33pyriceboi's Avatar
Re: Bolt size of bottom strut
best is if you go to honda to buy the bolt from them to replace... dont go to ur homedepot or lowes to buy the bolt...
Old Jul 2, 2008
HonCiv02's Avatar
HonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond repute
definitely buy it from honda; that way you know that it is the right grade.
Old Jul 2, 2008
TRIZ's Avatar
I think that nut is welded on bro
Old Jul 2, 2008
HonCiv02's Avatar
^i guess i didn't even think that there may be another reason it won't come off; i.e. it is welded on. nice call triz.
Old Jul 2, 2008
Albertross's Avatar
Member
That's odd, though it does seem like it is welded on, don't know why it would be...
Anyway, thanks for the replies!
Old Jul 2, 2008
FALKEN's Avatar
Civicforums Junkie
umm...none of the bolts/nuts holding the struts to the rotors are welded on
Old Jul 2, 2008
Albertross's Avatar
Member
Anyone know the torque specification for that nut is? I used a 450 ft/lbs max torque impact gun, and it didn't budge. Gonna take it to a suspension shop tomorrow and see what they say.
Old Jul 2, 2008
FALKEN's Avatar
Civicforums Junkie
Torque specs: 116ft/lbs.
Old Jul 2, 2008
Rufus's Avatar
Jesus, i just make it as tight as I can but 116ft/lbs?
Old Jul 2, 2008
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
I had the same thing happen to me last week when I was trying to swap my suspension, broke one of my rachets too for putting a huge lever arm on it. I just put everything back together and said ****it.
let us know what the suspension shop ends up doing.
Old Jul 2, 2008
MrXclusivE's Avatar
thats not much really, its equivalent to a midget standing on a 1 ft wrench
Old Jul 3, 2008
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
i think 1 side is welded on
Old Jul 3, 2008
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
neither side is welded on, it's probably just really tight. soak it in PB blaster then try again. if that doesnt work, take some heat to it but watch the obvious stuff.
Old Jul 3, 2008
Albertross's Avatar
Member
I asked a buddy of mine, and he said to apply an extreme amount of heat on it, like a blow torch, and use a vice-grip to take it off. My main worry with this is that the threads on the bolt will warp... guess I should head down to the Honda dealership and get the bolt and nut. I'll let you guys know how it goes.
Old Jul 3, 2008
Jza's Avatar
Jza
Jza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the rough
Some of those bolts get damn tight. I don't understand.
When I took me hood off we had to torch one of 'em.
Old Jul 6, 2008
Albertross's Avatar
Member
A friend of mine tells me that he's not surprised at my situation. He had to do the same on his 1.6 EL, and said that it was common on Honda's to have a nut or bolt that felt like it was welded on.
Anyway, I lost the lock nut socket, so I can't work on my struts until I either find the socket or... I have no idea. -_- I'm told that if I have the original packaging I could just match up the code. Too bad I don't.
Damn, this sucks.
manfredww1
Jul 14, 2015 10:24 AM
fordover
Jul 11, 2015 09:10 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
ballmich
Jul 9, 2015 11:59 AM
muttleytm
Jul 8, 2015 04:13 PM
