help! progress front sway bracket broken--again!
Old Jun 9, 2008
gelshmoff's Avatar
gelshmoff is an unknown quantity at this point
Exclamation help! progress front sway bracket broken--again!
so i had more bad sounds creaking & bumping under the front of my car, so I took a look when I did my last oil change over the weekend.
I've got the progress front & rear sway bars on there , with grey's endlinks on the front ONLY (stock endlinks on the back). everything else is stock.
So I look under there, and the bracket bolting the sway bar to the chassis is broken! This would be drivers side; the bolt towards the front of the car. The front flange of the bracket has a clear break in it at the corner of the u-shape, making my sway bar attached on that side by one bolt!
Luckily, when this happened before, I had called progress. and bought 2 extra brackets. so I slapped my extra bracket on. but what's the deal? They shouldn't be breaking like this.
Is it the endlinks? Are the crappy boston roads at odds with my sway bars? Any ideas??
Old Jun 9, 2008
mkymonkey's Avatar
I haven't been here in a long time
mkymonkey is a jewel in the roughmkymonkey is a jewel in the roughmkymonkey is a jewel in the roughmkymonkey is a jewel in the rough
Re: help! progress front sway bracket broken--again!
http://www.dezod.com/pd_dezod_motors..._spec_rear.cfm
buy those I am
Old Jun 9, 2008
ive never had a problem with dezod links front and back but i have the rsx bar which doesnt have bracket. it shouldnt be breaking like that, sounds like some sort of defect on progress' side.
Old Jun 10, 2008
robbclark1's Avatar
Retired suspension supermod.
He isn't talking about ENDLINKS. He is talking about BRACKETS!
I've never had a problem with mine, but they do get salty and may wear out. Maybe trying painting or clear coating them to protect them from the salt.
Old Jun 10, 2008
oh that metal plate that says progress on it? does it even affect the performance? or just for looks.
Old Jun 10, 2008
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
you're thinking about the rear, that's the tiebar. he's talking about his front sway bar brackets that hold the bushings.
Old Jun 10, 2008
robbclark1's Avatar
well both the front and the rear have the same brackets. Yes, he is talking about the brackets around the bushings. If it is broken, the the bar doesn't do its job.
Old Jun 10, 2008
^ true. just clarifying it was the front though.
i need to grease my bushings like no other. my car squeaks and creaks so bad, sounds like a machine gun when i jack it up.
Old Jun 10, 2008
robbclark1's Avatar
Works wonders!
Old Jun 10, 2008
Old Jun 10, 2008
gelshmoff's Avatar
yeah, it's the bracket. to clarify, the bracket was broken, but the bolt was still holding the broken flange to the chassis.
but would big pot holes cause this bracket to break? or perhaps something like a big set of railroad tracks or a driveway with a megasteep entry?
i gotta say to Grey. Grey's endlinks > sway bar bracket
Old Jun 12, 2008
gelshmoff's Avatar
any ideas as to the cause of this?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
old97civic
Jul 9, 2015 12:19 PM
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
