Kontrol pro and Camber kit?
Old Apr 30, 2008
JamesI52's Avatar
JamesI52 is an unknown quantity at this point
I just ordered my Ksport Kontrol pro coilovers and I had been reading that I wouldn't need a camber kit for them because it had camber adjustment incorporated.
when I ordered the kit I asked whether I needed a camber kit as well. The people said I would, and that it was the camber of the coilover that could be adjusted? so I am confused I went ahead and ordered a camber kit anyway just to be safe. I figure since they blatantly said i was wrong and needed one, if i turn out to be right, I will make them refund it.
Old Apr 30, 2008
robbclark1's Avatar
Retired suspension supermod.
Re: Kontrol pro and Camber kit?
What kind of civic?
If it is a 7thgen (2001-2005), please read the suspension FAQ. You will need a rear camber kit. Front has camber plates, which alignment tech notoriously do not know how to use unless you tell them. I suggest getting educated a bit before install and alignment or you will end up with something wrong.
Old Apr 30, 2008
JamesI52's Avatar
ok thank you yeah Ill do some reading
my car is an 02 LX sedan
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
