Am I missing anything when install a 19mm RSX rearsway bar?
Okay I shall be installing a 19mm RSX rear sway bar onto my 03 Civic 4-Door EX
this is what I have so far:
19mm RSX Rear Swaybar
OEM RSX Endlinks
Energy Suspension Rear swaybar bushings + Brackets
Marine Grease
is this all I need to install the rear-swaybar
am I missing anything
thanks for your help
Ps. I searched could not find a solid answer to see if I am indeed missing anything.
OEM RSX Endlinks
Marine Grease
Re: Am I missing anything when install a 19mm RSX rearsway bar?
I'm not sure to the answer of your question, but what a coincidence! Mine is coming in tomorrow! It's the 05-06 one though.
Assuming the rsx endlinks work, it sounds like you have everything. The only think you didnt say you had were the bolts to hold the brackets in- you'll need these.
Oh, and tools!
Oh, and tools!
looks like you got just about everything you need.. have fun!
you can use the stock endlinks if the RSX ones don't work and i'm pretty sure you can use the stock bolts from your OEM EX sway bar brackets..
New Mod on the Block
you'll need a socket set as well... you said anything...
. you're stock endlinks will work. i have an 03 EX sedan as well, and i just took off the old one and put the new one on. no grease or anything. it bolted up perfect, so you don't have to worry.
. you're stock endlinks will work. i have an 03 EX sedan as well, and i just took off the old one and put the new one on. no grease or anything. it bolted up perfect, so you don't have to worry. Joined: Aug 2001
You don't need the RSX endlinks. Yours will work fine, so you wasted your money.
A descendant of 2k1civic.com
I have the bigger RSX Rear Sway coming. The 21mm? (don't feel like looking it up). From the type S.
My question is. I have an LX, so I would need everything above that "vtec concept" is using plus the Progress rear sway bar adapter kit, right?
Is Progress the only one that makes these?
Nice thanks again everyone!
and the RSX Endlinks came with the swaybar...
but yes I have the bolts, and tools and allen keys too
as well a nice torch to get all the bolts all nice and hot.
Rogelio Rey
May 24, 2015 08:30 PM
usajags84
Apr 10, 2015 09:54 PM
