Squeek/Crunk Noises in Passenger Rear
Old Apr 5, 2008
qijian's Avatar
Well as i've been trying to figure this problem out for awhile, i see some people say its the bushings are done or something with bearings. Does anyone know where these *bearings* or *bushings* are that might be done and be replaced? pics would even be better, or just a general look on where it might be would be great. Thanks!
Old Apr 5, 2008
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
Re: Squeek/Crunk Noises in Passenger Rear
I have exact same problem. checked it out on the lift yesterday and bushings seem to be fine. I'm suspecting the upper shock mounts now, gonna check it out in a few hours...
Old Apr 5, 2008
DDragon7's Avatar
I think I've got a similar problem. But I thought it was coming from the rear passenger side, but was actually the front passenger side. Can seem to find the problem of the squeek, but the clunk maybe coming from a slightly loose swaybar endlink. It could also come from my shocks, which I feel are near dead due to the huge pot holes from the huge storm we had in March.
Old Apr 5, 2008
kcari's Avatar
i have a squeek in the front passenger side only if someone sits in it and when the car is in emotion. I had it when I was on springs and stock shocks and still have it now with cull coilovers. It's getting louder and louder...
Old Apr 7, 2008
qijian's Avatar
problem fixed. got bored this weekend so i took a look under the car to see if i can find anything to grease up since people said it might work. Found out it was the sway bar bushings in the middle... or might be the sway bar itself... because a friend lend me his rsx sway bar and after installation....it was magical, no more sounds at all...amazing. Also i found out the old ex sway bar bushings had almost no grease left in it, so that might of caused the sounds. its the ones under the bracket that holds the sway. a weekend well spent (=
Old Apr 7, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Ask your passenger what he ate last night.
Old Apr 7, 2008
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
whatever it was, i think he may have been hanging out with lil jon. OOOOOOOOOOKAAAAAAAAAAAAAAAAAAAAAAAAAAY!
my suspension makes so much damn noise. me = lazy.
Old Apr 7, 2008
qijian's Avatar
mines been bothering me for quite awhile and i finally got rid of it. hopefully it wont come back.... or ima be really annoyed...once again. =[
Old Apr 7, 2008
slowwhitecivic's Avatar
slowwhitecivic will become famous soon enough
i had the same problem...wd 40 and some grease shut taht **** up quick hahaha
Old Apr 7, 2008
DeX's Avatar
DeX
Canadian, Eh!
WD40 is not a lubricant, that's a myth. It's marketed and sold as a rust inhibitor.
Old Apr 7, 2008
qijian's Avatar
grease, thick grease ftw!!
Old Apr 8, 2008
yeah you need real auto grease. wd40 serves no purpose.
rtachs
Jul 16, 2015 05:32 PM
Foggy60
May 30, 2015 03:51 PM
pratik05
May 15, 2015 01:54 PM
civicns
May 8, 2015 09:49 PM
PimpBot5000
Nov 26, 2001 07:15 PM
