Which Springs? Cant search!
Old Mar 23, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
Options:
Eibach Pro-Kit
H&R Sport Springs (wont let me search)
Tein S-Tech's
Nuespeed Sports
Im 17, and I carry passengers in the back of my coupe often. I also have an audio system of 3 10's and an amp.
I looked through the entire Suspension Drop thread but a lot of the pictures dont work anymore
So basically, with no one in the back, all Im looking for is an front/back even drop or with the front a lil lower
The impression im getting is that the H&Rs drop around 1.7 vs. the advertised 1.3. Any help appreciated!
Current Rear Fender Gap:
Nothing more than 1.75"!!!
Old Mar 23, 2008
robbclark1's Avatar
Retired suspension supermod.
Re: Which Springs? Cant search!
Why not get full coils so you can adjust the height?
Old Mar 23, 2008
MarkieMark's Avatar
MarkieMark will become famous soon enough
yeah i was trying to search up the h&r too.
i was suppose to get those but i'm going ground controls now.
just waiting on a quote..
Old Mar 23, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
All the springs will work the same and give a good ride height. I don't know what you're specifically asking.
Old Mar 23, 2008
Envy's Avatar
Diamond Member
i was asking which are gunna be semi sag-free. aka wont rub with ppls in the back. i cant afford coils yet, although i wish i could.
Old Mar 24, 2008
DeX's Avatar
DeX
Canadian, Eh!
Best thing would be to check the compression rates of the springs if there is such a thing. Basically find out the stiffness. I put a few hundred pounds of gear in the back of my car and drove across the country, I was about half a millimeter from rubbing the entire way, constantly had to get out at every gas station and check it.
Old Mar 24, 2008
Envy's Avatar
Diamond Member
well the H&R's are progressive spring rate. so i cant check. and theyre at the top of my list. maybe ill just eat the cost and go eibach.
Old Mar 28, 2008
LatinEM2's Avatar
LatinEM2 is a glorious beacon of lightLatinEM2 is a glorious beacon of lightLatinEM2 is a glorious beacon of lightLatinEM2 is a glorious beacon of lightLatinEM2 is a glorious beacon of lightLatinEM2 is a glorious beacon of light
I have Eibach Sportlines, look at my sig. If your going to drop on stock struts expect them to blow soon and then you'll be bouncing
Sep 26, 2023 06:44 PM
Rlss
24
Feb 26, 2016 09:42 PM
scotchtape
Sep 18, 2015 04:15 PM
cukaracha
Aug 29, 2015 05:27 PM
Curtchuk
Aug 5, 2015 02:14 PM
