werid spring noise in rear
Old Feb 13, 2008
qijian's Avatar
so im lowered on blues+ stechs and everything seems to be fine till i drive it out and make a wide left turn or fast left turn... it starts to make this *crunk crunk* noise, and its only coming from the spring in the rear on the right side. So i just wondered if anyone knows what it might be? Did i install it incorrectly? *yes i DIY* Is the bottom of the spring suppose to point outwards towards the wheel or inward towards the center of the car? I tried putting it both ways but still getting the problem. So, what you guys think?
Old Feb 13, 2008
Re: werid spring noise in rear
is it like a creaking noise? could be you just have to lube the rear sway bushings.
Old Feb 13, 2008
qijian's Avatar
it sounds more like the spring turning or something because it goes crrrr*unk. Where is the rear sway bushings?
Foggy60
May 30, 2015 03:51 PM
vtec_concept
May 24, 2015 10:27 AM
oneheadlight
Apr 29, 2015 11:30 PM
Thees1
Apr 14, 2015 08:23 AM
SugarRay
Dec 6, 2001 05:17 PM
