i have 2 questions.
Old Oct 2, 2007
mrbanhbao's Avatar
mrbanhbao has a spectacular aura aboutmrbanhbao has a spectacular aura about
i have 2 questions.
1. i dont know if this is okai or not but i lowered my car on some non full skunk2 coilovers 5-6 months ago. the front left and right gap is 2 fingers and the rear are 1 finger gap. is that bad or good ...?
2. the driver side coilover is making some clunking sound whenever i drive over a small bump or uneven road. the sound is like the springs are moving around and knocking into things or its bouncing up and down and hitting the top iono how to describe it but i hope someone know what im talking about.
Old Oct 2, 2007
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
Re: i have 2 questions.
non full coilovers? uh.... so you got coilover sleeves? if you did, anything over 1.5inches require aftermarket shocks to cope with it. alot of people have blown their stock struts and alot havent. it varies.
is it only the driver side coilover? how many miles do you have on your car? what was included with your coilover sleeves when you got them?
Old Oct 2, 2007
mrbanhbao's Avatar
yeah coilover sleeves. im running those on stock struts yeah and its only driver side and i got like 74XXX miles on it but prolly 3xxx on them coilovers. i got the springs, sleeves, the top cap ( iono wats it called ) rubber o rings. umm the tools to tiighten them. thas all i think
Old Oct 3, 2007
robbclark1's Avatar
Retired suspension supermod.
1) The drivers side is heavier so you can't lower it as much as the passenger side.
2) Get under the car at look at coilovers.
Old Oct 3, 2007
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Did you just compress, "I don't know" into a single word?
Old Oct 3, 2007
blinknfgkicks's Avatar
blinknfgkicks will become famous soon enoughblinknfgkicks will become famous soon enough
check the top of the strut tower in your engine bay, and make sure the middle bolt is tight. (going to need an hex key and a wrench to tighten it)
mine was loose and it made its weird sound every time i went over a bump or something
Old Oct 3, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
check to see if the exhaust isnt bumping off your lower suspension arm or swaybar mount?
SidCivic
Oct 3, 2015 06:00 AM
sccarally
Texas
Sep 27, 2015 03:33 PM
kevfarr
Sep 18, 2015 02:28 PM
SidCivic
Sep 12, 2015 05:28 PM
chadds
Sep 9, 2015 05:26 AM
