Rear suspension making noise over bumps
Old Jun 19, 2007
davidoff1's Avatar
davidoff1 is an unknown quantity at this point
Hi,
I have a sedan, and it's about 2 weeks my rear suspension (right side) is making squeky noise when I drive slowly over bumps or uneven roads. I took the wheel out and checked.. can't find anything wrong.. bushing is fine.. suspension is fine (just replaced stock ones with tokico blue recently)...
so I sprayed some WD40 on all the joints... and the noise went away for 1 day and came back again... and I took it to a shop to check and they said the same thing... nothing wrong everything is tight... they told me just lub it every time I do oil change....
Do you guys have similar problem? wat could be the problem?
Thanks!!
Old Jun 20, 2007
Syke Fu's Avatar
Syke Fu will become famous soon enough
Re: Rear suspension making noise over bumps
You lowered?
Old Jun 20, 2007
davidoff1's Avatar
Originally Posted by Syke Fu
You lowered?
Yes it's lowered with neuspeed sports...
Old Sep 13, 2007
znas's Avatar
znas is an unknown quantity at this point
Same issue here, mechanics said everything is good to go. However, sound kept coming back. I basically gueseed, and replaced the control arm and trailing arm bushings and magic!! no more sound.
Old Sep 13, 2007
greeen01civic4d's Avatar
if u have a camber kit, its the camber kit squeaking, if not its the front lower knuckle bushing, honda has a tsb about it
Old Sep 24, 2007
kcari's Avatar
I feel for you bro... i have the same problem. Taken it 3 different shops, and to a friend who knows a thing or two about suspensions and they all say everything looks fine. It has gotten a lot better - though, seems like something settled and I only hear it when I go over speed bumps now. Before driving slowly or bumpy road, I'd hear it. I'll just wait a few months and next time I go in for an alignment, I'll have it checked out again. But what can I say, everyone says that noise is not normal yet they can't find anything wrong with the car....
and im lowered on S-techs and factory everything else.
And the noise only happened AFTER the installation. Someone mentioned it was something with the lining of the springs, had to realign them or something, but once again, my car seems good to go.... rides nicely when going fast.
Old Sep 24, 2007
davidoff1's Avatar
I sprayed some wd40 on the spring and strut the noise went away....
dosmastr
May 5, 2015 12:19 PM
oneheadlight
Apr 29, 2015 11:30 PM
SSMatey
Apr 13, 2015 06:09 PM
PimpBot5000
Nov 26, 2001 07:15 PM
Sparty
Nov 15, 2001 04:55 PM
