Tein project turning into a 2-3 weeker
Old Jun 16, 2007
alcopaulic's Avatar
alcopaulic is an unknown quantity at this point
Ok, last weekend i started my tein basic coilover install. Thanks to mex for his printable DIY it gave my cheap printer a workout but it was well worth it. I posted pictures of the project and i'm still currently working on it for many reasons. The fronts i got off with a torn tie rod boot as my only victim. pretty easy install, took about 3 slowly drank miller high lifes worth of time. then came the rears, i was all ready to go when i found that the 17mm bolt wasn't budging. No impact to use in sight. So i used my buddie's gf's run down Hyundai accent to run to the local hardware store and pick up a socket to fit the breaker bar i had. Soaked it in pb blast. then tried again. no luck. Hammered on it. no luck. put an extension on the socket, attached the breaker bar, came through the wheel well (for more leverage), attached a jack handle to the break bar, put everything i had into it. and it torqued the extension in half. No luck. So i gave up on the project until i could get an impact wrench. drove my car away, and found my steering wheel to be cocked to the right, while i was driving straight. I'll continue on that in a bit. Got an impact from a guy at work last night, and found my 17mm impact socket to be too long to fit that with the impact between the bolt head and the rear suspension link. I finally finaggled it in, impacted away, and the bolt still won't budge. I'm getting pretty frustrated at this point. My new options are, torching the bolt, and i'll buy one more non-deep well socket today to give it another try. So here are the questions i have. Any other ideas on how to get that rear bolt out? I have read that in order to replace the tie rod boot i'll need a special honda tool. anyone have any "alternative" tool ideas to use to replace that boot? what's up with the crooked steering wheel? i've read on here that it's an alignment issue and once i get it aligned it'll go away, but it seems to me that i'd need to lengthen one tie rod and shorten the other for it to straighten out. and lastly besides local shops, any nation wide places that do good alignments that you guys know of? Anyways, i'll take more pics of the final product when i finally get it done.
ID:	71502   Click image for larger version
ID:	71503   Click image for larger version
ID:	71504   Click image for larger version
ID:	71505   Click image for larger version
Old Jun 16, 2007
johnbt23's Avatar
Re: Tein project turning into a 2-3 weeker
the alignment will fix the crooked steering wheel problem. same thing happened to mine, except mine was crooked to the left. as far as getting your alignments somewhere, i got mine at sears, and i haven't had any problems at all. good luck getting that bolt out.
Old Jun 16, 2007
speedfoos's Avatar
Yeah, best bet would be to take it to any shop for an alignment, especially after changing the entire suspension. You could get your steering wheel straight by adjusting the tie rods (which is part of an alignment), but without the proper equipment it won't be right and it will pull and/or wear your tires prematurely. Alignments are one thing you can't eyeball.. You've completely changed the suspension profile, so it needs to be done. Sears or any other large auto shop should have an alignment rack.
For the rear, PB blaster, a torch, a breaker bar or impact wrench are your best bets. It'll come off, its just mired on there (I win awards for being obvious..). When using a breaker bar, use steady pressure and there will less chance of something snapping. There's really no other way to do it.
Old Jun 16, 2007
Da1lyDr1ver's Avatar
as for your rear bolt that wont budge... make sure you're trying to loosen the correct bolt. theres a bolt that people commonly mistaken for loosening, when in fact, it is welded onto the a-arm (i think thats the part). you have to go from behind.
sorry if thats confusing, but if you dont know what i'm saying than nevermind me!
Old Jun 16, 2007
EJOman's Avatar
EJOman is on a distinguished road
^^ That is the truth man, but its kinda obvious when your down there. My instal on my coils went very smooth, but now they kinda make a creaking noise when i trun the wheel hard, IDK I havent had time to jack it up yet, so hopefully its not doing damage...
Old Jun 19, 2007
SedanDriver's Avatar
SedanDriver is an unknown quantity at this point
When I did my eibach sportlines I had the same problem with the rear lower shock mounting bolt. I ended up using a Sawzall to cut the bolt. took 2 minutes. I kinda nicked the lower shock mount so I just ordered new rear shocks from honda. Would it happen to be the left rear lower bolt?
Old Jun 19, 2007
alcopaulic's Avatar
Ok, here's an update, i got the passenger side rear off at work with a torch, and using an impact, tightening, then loosening, and over and over again until it finally had enough momentum to loosen. the other side, now THIS is going to be a problem, i tried the same thing, and it's stripped, either the bolt or the welded on nut. it just turns in place, doesn't go in, doesn't go out. So, i was going to torch the welded on nut off, try and easy-out the remaining bolt. and weld another bolt on. How's that for an operation, just to put some F#$%'n coilovers on.
Old Jun 19, 2007
HighBoost's Avatar
HighBoost is an unknown quantity at this point
Is gettin hot in here ~!! we can all see that u have been workin very hard this coilover, is all about using the right tool maan. if it continuously giving u trubles, y dont u just take it to the shop
Old Jun 20, 2007
speedfoos's Avatar
Shops are for suckas. Keep at it man!
Old Jun 20, 2007
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
good luck with your rear install...it was biatch for me too...i worked alone on my car...rear took 3 hours each...
damn nut stripped for me too...had to use hammer to get nut out...i will try to find the nut for pics if i can find it
Old Jun 20, 2007
aznsupaboy's Avatar
aznsupaboy is an unknown quantity at this point
i had a lil trouble with my rears too but the thing is that i had a friend help me out with the rear. as far as u not being able to take the nut out... wut i did was i stepped on top of the wheel and applied pressure to push it down far enough to where my buddy was able to pull out the nut. same thing applies when ur putting it back in. the one that ur supposed to torque is if ur looking at ur rears its the bolt thats facing the rear of the car. i don't know if that's wut ur talking about. maybe some pics of where ur at would help to clarify things up a lil?
Old Jul 26, 2007
jamis33's Avatar
You Stay Classy, San Diego
hey do u still have that long diy install sheet?
Old Jul 26, 2007
TRIZ's Avatar
Hook your socket and wrench up, no breaker bar, and tap the end with a hammer. Its something about brute force that has broken many of my sockets (craftsman) due to stuborn bolts, and then I tap the back with a hammer instead of pulling my brains out, and it comes off every time.
Old Jul 26, 2007
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
Triz is right. Tapping with a hammer works very well. It's too bad you've stripped the nut. I hate it when that happens, it just escalate your problems to another level. It's gonna be a bitch putting the coilovers in too, just not enough room to work with. Well good luck bro.
Old Jul 26, 2007
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
When I brought my car in to have the suspension changed they told me I might get charged an extra $120 for labour if any of the rear bolts are seized and they won't know until I get it in there. I thought he was trying to rip me off so I did the install myself. Now I know he wasn't lying. It can happen I guess.
As for an easier way of getting the tie rod out without ripping the boot, don't even touch the boot. Take out the cotter pin and turn the nut so it's hanging off the end of the tie rod bolt. Then beat upwards on the nut with a hammer until it comes free. Then put the nut all the way back on and take it all the way off to straighten out the threads again. Worked fine for me.
reqy
Jun 1, 2015 07:05 AM
elitezdc5
May 26, 2015 05:46 PM
civic_gt
Apr 19, 2015 08:15 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
