Popping noise when turning (new springs)
Old Mar 24, 2007
asianmatrix02's Avatar
asianmatrix02 is an unknown quantity at this point
I just installed tein s springs and there is a popping noise when turning at low speeds. I have read forums that the struts were not installed properly and I know how to fix it, but the question is that I am about to get the car aligned at Meineke and wanted to know if this alignment will fix this popping issue? I don't want to waste my time trying to fix it myself if getting this car aligned will solve the problem as well.
Old Mar 25, 2007
robbclark1's Avatar
Retired suspension supermod.
Re: Popping noise when turning (new springs)
No the alignment will not fix the noise. Alignments don't touch the suspension, they just move the whole suspension into specs. If you read how to fix it, then why would an alignment fix your problem? Read the FAQ and indexing thread.
Old Mar 25, 2007
from what i read, it is a misalignment of the top bearings, mounts, and struts, so i did not know if getting an alignment will fix this or not.
Old Apr 3, 2007
JeesunUltra's Avatar
JeesunUltra is an unknown quantity at this point
re-install your spings. the springs might be sliding off from the top mount
Old Apr 3, 2007
i got it fixed thanks
Old Apr 15, 2007
Alpha legends x's Avatar
Alpha legends x is an unknown quantity at this point
What did you do to get them fixed? i have (or still have slightly) the same prob with my springs. I have the same springs.
Old Apr 15, 2007
robbclark1's Avatar
He read the FAQ and learned how to index his shocks....
rtachs
Jul 16, 2015 05:32 PM
civicns
May 8, 2015 09:49 PM
edgenet
May 2, 2015 08:00 PM
cloudguy
Apr 28, 2015 05:02 AM
Russps
Nov 8, 2001 02:00 AM
