18s - do I need a camber kit?
Old Mar 20, 2007
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Will I need a camber kit?
I just bought some 18 inch Tenzo-R Drive X-7 wheels from a shop and I have a 2005 coupe. Has anyone put 18s on and not needed a camber kit? I don't know if I'll be lowering it on springs/struts or coilovers yet, does it matter in regards to needing a camber kit?
Old Mar 20, 2007
lownloudnyc's Avatar
lownloudnyc is an unknown quantity at this point
If your just going to put the rims on it wont make a diffrence but once you lower it you will need a camber kit no matter if you get coilovers or shocks and springs
Old Mar 20, 2007
hoanger's Avatar
hoanger is an unknown quantity at this point
Re: 18s - do I need a camber kit?
if the drop is moer than 1", you will need a camber kit, mainly for the rear
just putting rims on doesnt effect camber
you will need an alignment though
if you don't care about changing tires every season, you can live without a camber kit... although its a good investment
Old Mar 20, 2007
LilWannabeJdm's Avatar
LilWannabeJdm can only hope to improve
i got 18s and i got cambers..i didnt put my rims on until i got the cambers install since it was \ in the rear...i didnt want the tire to get eatten up by the negative camber i got...
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
