eiback pro kit
Old Jan 27, 2007
03blackcivic's Avatar
03blackcivic will become famous soon enough
eiback pro kit
hello i just wanted to know if i use the pro kit can i leave my stock strut and shock? if not then since kyb agx are only for 01,02 then what would be another sound set up? thanks
Old Jan 27, 2007
hondoer27's Avatar
hondoer27 will become famous soon enoughhondoer27 will become famous soon enough
You will be fine on stock ones for now but sooner or later they will go bad. Believe me I am running on a bad set right now my girlfriend calls my car THE BUNNY
Old Jan 27, 2007
EastBayStuntN's Avatar
EastBayStuntN is an unknown quantity at this point
call up a tech at The Tire Rack - Your performance experts for tires and wheels
i remember it was either them or a member here that said the eibach pro kit will be fine with the OEM struts as it wont put much stress as compared to the sportline kit, neuspeed sport/race, etc. but that still doesnt mean your struts has a chance to blow.
i personally run eibach sportlines/koni yellows and love it.
Old Jan 27, 2007
phuviano's Avatar
Slowest 7thgen in the GTA
You could leave the stock struts and shocks, but as many people on this board know. Our struts and shocks usually end up going bad after lowering it.
I would just buy some sort of aftermarket shocks and struts. You don't want to change your shocks and struts shortly after lowering the car. Its a waste of time if your doing the install yourself. Its a waste of money if your paying someone to do the install. You would have to pay someone to lower your car, and say you end up blowing the suspension. Then you would have to buy new suspension, and pay to install that as well.
I would also just go for aftermarket struts and shocks to reduce bouncing. I would hate to ride on stock shocks and struts, bouncing around everywhere.
I'm pretty sure you make any suspension fit 03-05 even if says 01-02 only. The only differences is the bolts on the front struts. 14mm for 01-02, and they are bigger on the 03-05's (16mm instead). All you have to do, is increase the size of the hole on the front struts to 16mm. I did that with my struts, and they work fine. Lots of members with 03-05 have done that as well.
Remember, this is just my opinion. You can do whatever you feel is right though. I say "if you're going to do something, do it right the first time".
Old Jan 27, 2007
thank you guys for such quick and helpful responses. since my friend has a shop with a spring compressor(it think thats what they are called) and wont charge me anytihng i will stat off with just the springs my car it has 65000 on it and i hope it will last another ten to fifteen as far as the struts and shocks.
Old Jan 27, 2007
Kevbotron's Avatar
I like my commute
Yep, whatever everyone else said... I had the prokit w/ stock shocks for about a year until I just bought a set of blues in the group buy (325 shipped )
Old Jan 27, 2007
sliver01's Avatar
sliver01 is an unknown quantity at this point
Your stock struts will be fine. I have an 03 with 230,000 kms on it (144,000 miles). I bought the car new and had the pro-kit installed by the Honda dealership before I picked it up. I have had no problems, I originally had 17's on it (205/40's), 15 steelies in the winter with snows and now run 16's
(205/55's) in the summer.
All combinations worked fine but the 17'2 ride too hard, they all do because of the minimal sidewall. The 16's ride really nice and the combination with the springs gives it nice grip. The ride is important to me as I travel alot for work, it is not a modded out 7th gen by any means but this combo provides a more agressive stance than stock for sure.
Post some pics when you get it done.
Old Mar 6, 2007
electric130's Avatar
do you have pics of your ride with the 16's and the pro kit? i'm thinking of getting the pro kit and tokico blues to start and then get new wheels later. i was thinking of getting 17's, but i also drive a lot for work and want the ride to be smooth. i don't want much stiffer than stock. i've got an 02 LX with 14" stock steelies with hubs. will these look horrible with the drop untill i can afford new wheels? i can afford to do it all at once, but i can get the drop and the shocks now.
Old Mar 6, 2007
Kevbotron's Avatar
I like my commute
I just got my blues put on w/ my pro kit, and the ride is ten times better than stock
The ride is far more stable, and bumps are felt way less than stock shocks... and as far as the drop looks w/ 14" stock steelies go w/ a prokit VVVV
Old Mar 6, 2007
so it rides better than stock? it's not too stiff and bouncy? awesome! that's encouraging. did you need a camber kit?
Old Mar 6, 2007
Kevbotron's Avatar
I like my commute
yeah.. after a while the rear tires were getting bad so they put the SPC kit on too. I would say you don't HAVE to have it.. but I just want the longest possible life for my tires. The shocks are nice tho, there's a speedbump going to my house, and now I don't have to absolutely crawl to get over it
Old Mar 9, 2007
sliver01's Avatar
Electric, below are a couple of pics (both with the Eibach Pro-Kit and factory struts).
With 17" Advanti Racing Rims and 205/40/17's (this rode awful)
With 16" Momo Rims and 205/55/16's Michelin HydroEdge (rides great, car feels heavier and holds the road, smoother than stock).
Old Mar 9, 2007
sliver01's Avatar
Try These
[img=http://aycu29.webshots.com/image/12708/2000431072104919366_th.jpg]
[img=http://aycu29.webshots.com/image/12708/2000431072104919366_rs.jpg]
Old Mar 10, 2007
i love that look right there. i think that's what i'll go with. i'm working on getting a set of 16's right now. also, what lip kit do you have? that looks sharp too! thanks for uploading the pics!
Old Mar 10, 2007
sl33pyriceboi's Avatar
^hahhaha hes got batman on his skirts...
rs front and skirt.......ftw =]
Old Mar 10, 2007
slystad810's Avatar
It looks like that Michelin on the left front if on backwards!
Old Mar 10, 2007
Kevbotron's Avatar
I like my commute
it is haha
Old Mar 10, 2007
lol hey, you cannot simply rotate those tires 03blackcivic.........
they are directional tires, which mean they only go one way....
so if u want to rotate, u needa put rear tire up front, and front tire to the rear.... no crisscrossing
Old Mar 18, 2007
sliver01's Avatar
The front and side skirts are oem sedan (veloz) ones (fit coupe), the back one is also a oem skirt.
Yes, that's batman, I have two young boys.........that is for them (just fro fun). Good eye, most people don't pick up on them as they are subtle.
Old Mar 18, 2007
sliver01's Avatar
Oh yeah, as for the Michelin's going the right direction, this is an old pic, was fixed.....Honda actually put them on this way....go figure. Right now I am riding on my 15 steelies/x ice combo until the snow is gone.....
Old Mar 22, 2007
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
Re: eiback pro kit
i think the prokits only give you about a inch drop?? you should be fine for a while. i used to have the sportlines and that gave me about 1.4 inch drop and my shocks were fine for a while. and keep in mind that springs will sag a little over time
Old Mar 23, 2007
familycar's Avatar
Re: eiback pro kit
i run the pro kit with the kyb agx's and love the ride. its 10x better than stock and still has the sproty feel of a lowered car but is pleanty soft enough for a long drive. considering the shocks are adjustable a well you can tune to your liking. i run 225/40/18 with them with out any rubbing, but my rear lip is shaved down as well
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
krazykoncepts
Sep 8, 2015 09:02 PM
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
